Cpu > 100 % ; Erreur : ETELEGRAM: 409
mon instance Gladys est installée sur un mini-pc et il fait souvent beaucoup de bruit.
Gladys tourne à plus de 100% ; docker stats renvoie :
J’ai regardé les logs de Gladys et j’obtiens ça :
2023-08-24T12:07:44+0200 <warn> handleMqttMessage.js:106 () Zigbee2mqtt device Capteur Luminosité Salon, feature brightness_state not configured in Gladys.
2023-08-24T12:07:47+0200 <warn> handleMqttMessage.js:106 () Zigbee2mqtt device MultiPrises Salon, feature power_outage_memory not configured in Gladys.
2023-08-24T12:07:50+0200 <warn> message.connect.js:19 (TelegramBot.<anonymous>) Telegram polling error, code = ETELEGRAM, message = ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
2023-08-24T12:07:53+0200 <warn> handleMqttMessage.js:106 () Zigbee2mqtt device Prise MiniPC, feature indicator_mode not configured in Gladys.
2023-08-24T12:07:53+0200 <warn> handleMqttMessage.js:106 () Zigbee2mqtt device Prise MiniPC, feature power_outage_memory not configured in Gladys.
2023-08-24T12:07:59+0200 <warn> handleMqttMessage.js:106 () Zigbee2mqtt device Capteur Luminosité Salon, feature brightness_state not configured in Gladys.
2023-08-24T12:08:00+0200 <info> scene.checkCalendarTriggers.js:24 (SceneManager.checkCalendarTriggers) Checking calendar triggers at Thu, 24 Aug 2023 10:08:00 GMT
2023-08-24T12:08:00+0200 <warn> message.connect.js:19 (TelegramBot.<anonymous>) Telegram polling error, code = ETELEGRAM, message = ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
2023-08-24T12:08:09+0200 <warn> message.connect.js:19 (TelegramBot.<anonymous>) Telegram polling error, code = ETELEGRAM, message = ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
2023-08-24T12:08:13+0200 <warn> handleMqttMessage.js:106 () Zigbee2mqtt device Capteur Luminosité Salon, feature brightness_state not configured in Gladys.
2023-08-24T12:08:14+0200 <warn> handleMqttMessage.js:106 () Zigbee2mqtt device Capteur Luminosité Salon, feature brightness_state not configured in Gladys.
2023-08-24T12:08:19+0200 <warn> message.connect.js:19 (TelegramBot.<anonymous>) Telegram polling error, code = ETELEGRAM, message = ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
2023-08-24T12:08:28+0200 <warn> handleMqttMessage.js:106 () Zigbee2mqtt device Capteur Luminosité Salon, feature brightness_state not configured in Gladys.
2023-08-24T12:08:28+0200 <warn> message.connect.js:19 (TelegramBot.<anonymous>) Telegram polling error, code = ETELEGRAM, message = ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
2023-08-24T12:08:35+0200 <warn> poll.js:14 (RtspCameraHandler.poll) Unable to poll camera
2023-08-24T12:08:38+0200 <warn> message.connect.js:19 (TelegramBot.<anonymous>) Telegram polling error, code = ETELEGRAM, message = ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
2023-08-24T12:08:39+0200 <warn> poll.js:14 (RtspCameraHandler.poll) Unable to poll camera
2023-08-24T12:08:43+0200 <warn> handleMqttMessage.js:106 () Zigbee2mqtt device Capteur Luminosité Salon, feature brightness_state not configured in Gladys.
2023-08-24T12:08:47+0200 <warn> message.connect.js:19 (TelegramBot.<anonymous>) Telegram polling error, code = ETELEGRAM, message = ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
2023-08-24T12:08:47+0200 <warn> handleMqttMessage.js:106 () Zigbee2mqtt device MultiPrises Salon, feature power_outage_memory not configured in Gladys.
2023-08-24T12:08:57+0200 <warn> message.connect.js:19 (TelegramBot.<anonymous>) Telegram polling error, code = ETELEGRAM, message = ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
2023-08-24T12:08:57+0200 <warn> handleMqttMessage.js:106 () Zigbee2mqtt device Capteur Luminosité Salon, feature brightness_state not configured in Gladys.
2023-08-24T12:09:00+0200 <info> scene.checkCalendarTriggers.js:24 (SceneManager.checkCalendarTriggers) Checking calendar triggers at Thu, 24 Aug 2023 10:09:00 GMT
2023-08-24T12:09:06+0200 <warn> message.connect.js:19 (TelegramBot.<anonymous>) Telegram polling error, code = ETELEGRAM, message = ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
2023-08-24T12:09:12+0200 <warn> handleMqttMessage.js:106 () Zigbee2mqtt device Capteur Luminosité Salon, feature brightness_state not configured in Gladys.
2023-08-24T12:09:16+0200 <warn> message.connect.js:19 (TelegramBot.<anonymous>) Telegram polling error, code = ETELEGRAM, message = ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
2023-08-24T12:09:22+0200 <info> lan-manager.scan.js:19 (LANManager.scan) LANManager starts scanning devices...
2023-08-24T12:09:25+0200 <info> lan-manager.scan.js:57 (NmapScan.onSuccess) LANManager discovers 16 devices
2023-08-24T12:09:25+0200 <info> lan-manager.stop.js:12 (LANManager.stop) LANManager stops scanning devices
2023-08-24T12:09:25+0200 <warn> message.connect.js:19 (TelegramBot.<anonymous>) Telegram polling error, code = ETELEGRAM, message = ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
2023-08-24T12:09:26+0200 <warn> handleMqttMessage.js:106 () Zigbee2mqtt device Capteur Luminosité Salon, feature brightness_state not configured in Gladys.
2023-08-24T12:09:27+0200 <warn> handleMqttMessage.js:106 () Zigbee2mqtt device Capteur Luminosité Salon, feature brightness_state not configured in Gladys.
Voilà aussi les logs de node_red :
Unhandled rejection Error: ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    at /data/node_modules/node-telegram-bot-api/src/telegram.js:299:15
    at tryCatcher (/data/node_modules/bluebird/js/release/util.js:16:23)
    at Promise._settlePromiseFromHandler (/data/node_modules/bluebird/js/release/promise.js:547:31)
    at Promise._settlePromise (/data/node_modules/bluebird/js/release/promise.js:604:18)
    at Promise._settlePromise0 (/data/node_modules/bluebird/js/release/promise.js:649:10)
    at Promise._settlePromises (/data/node_modules/bluebird/js/release/promise.js:729:18)
    at _drainQueueStep (/data/node_modules/bluebird/js/release/async.js:93:12)
    at _drainQueue (/data/node_modules/bluebird/js/release/async.js:86:9)
    at Async._drainQueues (/data/node_modules/bluebird/js/release/async.js:102:5)
    at Immediate.Async.drainQueues [as _onImmediate] (/data/node_modules/bluebird/js/release/async.js:15:14)
    at processImmediate (node:internal/timers:466:21)
L’erreur sur la caméra vient du fait qu’elle a un soucis que je n’ai pas encore corrigé.
Je ne sais pas si tout ça est lié.
Par hasard tu n’as pas utilisé la même clé d’API Telegram côté Gladys et Node-RED ?
Chez Telegram, une clé d’API = une connexion :slight_smile:
Si.
Je comprends donc qu’il faut en créer 2.
Je veux publier sur le même bot, c’est possible ?
Je suis pas sûr que ce soit possible… A tester limite
Sinon, il faudra créer 2 bots
