Hello to all integration developers,
If any of you want to develop an Intex PureSpa integration, I’m interested.
Thanks in advance.
Thanks in advance.
I’ll take it ![]()
Hello @jerome,
It’s done: the Intex PureSpa integration is available in version 0.0.1! ![]()
The principle
Gladys communicates directly with the spa’s Wi-Fi module on the local network (TCP port 8990). No Intex account, no cloud: it works even without the Internet.
What it does
Example: “every Friday at 2 p.m., heat the spa to 38 °C”, then “when the temperature is reached, send me a message” ![]()
Prerequisites
Installation
Full documentation: gladys-intexpurespa/docs/fr.md at main · prohand/gladys-intexpurespa · GitHub
I need you!
The protocol is the one used by the community (lib aio-intex-spa). I don’t have a spa on hand, so I haven’t been able to test with real hardware yet. Your feedback interests me:
Bugs can be reported here or on GitHub: Issues · prohand/gladys-intexpurespa · GitHub
Happy bathing! ![]()
Great! Thanks a lot @prohand
I’ll test this quickly. I hope tomorrow and I’ll give you feedback.
Great work getting this integration available so quickly! Local communication without depending on an external cloud is especially interesting for home automation. Real-world testing across different PureSpa models should help uncover compatibility issues. If testers need to exchange larger logs or configuration files, https://www.filemail.com/ is worth considering.
