Since two days ago docker will no longer start, after I updated the version that… worked to
Version: 5:18.09.0~3-0~raspbian-stretch.
After that the docker daemon will no longer start.
strace -f dockerd reports
```root@raspberrypi:~# strace -f dockerd
execve("/usr/bin/dockerd", ["dockerd"], [/* 27 vars */]) = 0
brk(NULL)                               = 0x3b13000
uname({sysname="Linux", nodename="raspberrypi", ...}) = 0
access("/etc/ld.so.nohwcap", F_OK)      = -1 ENOENT (No such file or directory)
mmap2(NULL, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f6e000
access("/etc/ld.so.preload", R_OK)      = 0
open("/etc/ld.so.preload", O_RDONLY|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=42, ...}) = 0
mmap2(NULL, 42, PROT_READ|PROT_WRITE, MAP_PRIVATE, 3, 0) = 0xb6f6d000
close(3)                                = 0
open("/usr/lib/arm-linux-gnueabihf/libarmmem.so", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\210\5\0\0004\0\0\0"..., 512) = 512
lseek(3, 20868, SEEK_SET)               = 20868
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1000) = 1000
lseek(3, 20540, SEEK_SET)               = 20540
read(3, "A,\0\0\0aeabi\0\1\"\0\0\0\0056\0\6\6\10\1\t\1\n\3\f\1\22\4\24"..., 45) = 45
fstat64(3, {st_mode=S_IFREG|0644, st_size=21868, ...}) = 0
mmap2(NULL, 86080, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6f2b000
mprotect(0xb6f30000, 61440, PROT_NONE)  = 0
mmap2(0xb6f3f000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0xb6f3f000
close(3)                                = 0
munmap(0xb6f6d000, 42)                  = 0
open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=28101, ...}) = 0
mmap2(NULL, 28101, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb6f67000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libsystemd.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\0\0\0\0004\0\0\0"..., 512) = 512
lseek(3, 493188, SEEK_SET)              = 493188
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1320) = 1320
lseek(3, 492748, SEEK_SET)              = 492748
read(3, "A2\0\0\0aeabi\0\1(\0\0\0\0056\0\6\6\10\1\t\1\n\2\f\3\22\4\23"..., 51) = 51
fstat64(3, {st_mode=S_IFREG|0644, st_size=494508, ...}) = 0
mmap2(NULL, 499173, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6eb1000
mmap2(0xb6f28000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x76000) = 0xb6f28000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\3\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0dI\0\0004\0\0\0"..., 512) = 512
lseek(3, 125740, SEEK_SET)              = 125740
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1560) = 1560
lseek(3, 90536, SEEK_SET)               = 90536
read(3, "A.\0\0\0aeabi\0\1$\0\0\0\0056\0\6\6\10\1\t\1\n\2\22\4\23\1\24"..., 47) = 47
fstat64(3, {st_mode=S_IFREG|0755, st_size=127300, ...}) = 0
mmap2(NULL, 164432, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6e88000
mprotect(0xb6e9e000, 61440, PROT_NONE)  = 0
mmap2(0xb6ead000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x15000) = 0xb6ead000
mmap2(0xb6eaf000, 4688, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb6eaf000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libseccomp.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\344\272\0\0004\0\0\0"..., 512) = 512
lseek(3, 139840, SEEK_SET)              = 139840
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1040) = 1040
lseek(3, 139504, SEEK_SET)              = 139504
read(3, "A,\0\0\0aeabi\0\1\"\0\0\0\0056\0\6\6\10\1\t\1\n\2\22\4\24\1\25"..., 45) = 45
fstat64(3, {st_mode=S_IFREG|0644, st_size=140880, ...}) = 0
mmap2(NULL, 205044, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6e55000
mprotect(0xb6e6c000, 65536, PROT_NONE)  = 0
mmap2(0xb6e7c000, 49152, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17000) = 0xb6e7c000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0@h\1\0004\0\0\0"..., 512) = 512
lseek(3, 1231820, SEEK_SET)             = 1231820
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 2880) = 2880
lseek(3, 1228284, SEEK_SET)             = 1228284
fstat64(3, {st_mode=S_IFREG|0755, st_size=1234700, ...}) = 0
mmap2(NULL, 1303872, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6d16000
mprotect(0xb6e3f000, 65536, PROT_NONE)  = 0
mmap2(0xb6e4f000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x129000) = 0xb6e4f000
mmap2(0xb6e52000, 9536, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb6e52000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libselinux.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0hN\0\0004\0\0\0"..., 512) = 512
lseek(3, 136448, SEEK_SET)              = 136448
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1160) = 1160
lseek(3, 136088, SEEK_SET)              = 136088
fstat64(3, {st_mode=S_IFREG|0644, st_size=137608, ...}) = 0
mmap2(NULL, 208496, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6ce3000
mprotect(0xb6d03000, 65536, PROT_NONE)  = 0
mmap2(0xb6d13000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x20000) = 0xb6d13000
mmap2(0xb6d15000, 3696, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb6d15000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/librt.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\3\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0 \27\0\0004\0\0\0"..., 512) = 512
lseek(3, 25352, SEEK_SET)               = 25352
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1280) = 1280
lseek(3, 24940, SEEK_SET)               = 24940
fstat64(3, {st_mode=S_IFREG|0644, st_size=26632, ...}) = 0
mmap2(NULL, 90640, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6ccc000
mprotect(0xb6cd2000, 61440, PROT_NONE)  = 0
mmap2(0xb6ce1000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0xb6ce1000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/liblzma.so.5", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\230\"\0\0004\0\0\0"..., 512) = 512
lseek(3, 131848, SEEK_SET)              = 131848
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1080) = 1080
lseek(3, 131500, SEEK_SET)              = 131500
fstat64(3, {st_mode=S_IFREG|0644, st_size=132928, ...}) = 0
mmap2(NULL, 197040, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6c9b000
mprotect(0xb6cbb000, 61440, PROT_NONE)  = 0
mmap2(0xb6cca000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1f000) = 0xb6cca000
close(3)                                = 0
open("/usr/lib/arm-linux-gnueabihf/liblz4.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\300\32\0\0004\0\0\0"..., 512) = 512
lseek(3, 66052, SEEK_SET)               = 66052
lseek(3, 65748, SEEK_SET)               = 65748
fstat64(3, {st_mode=S_IFREG|0644, st_size=67092, ...}) = 0
mmap2(NULL, 131288, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6c7a000
mprotect(0xb6c8a000, 61440, PROT_NONE)  = 0
mmap2(0xb6c99000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf000) = 0xb6c99000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libgcrypt.so.20", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\0\\\0\0004\0\0\0"..., 512) = 512
lseek(3, 787796, SEEK_SET)              = 787796
read(3, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 1120) = 1120
lseek(3, 787437, SEEK_SET)              = 787437
read(3, "A,\0\0\0aeabi\0\1\"\0\0\0\0056\0\6\6\10\1\t\1\n\7\f\3\22\4\24"..., 45) = 45
fstat64(3, {st_mode=S_IFREG|0644, st_size=788916, ...}) = 0
mmap2(NULL, 853676, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6ba9000
mprotect(0xb6c65000, 65536, PROT_NONE)  = 0
mmap2(0xb6c75000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xbc000) = 0xb6c75000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\200\321\0\0004\0\0\0"..., 512) = 512
lseek(3, 115292, SEEK_SET)              = 115292
lseek(3, 114944, SEEK_SET)              = 114944
fstat64(3, {st_mode=S_IFREG|0644, st_size=116372, ...}) = 0
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f65000
mmap2(NULL, 180536, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6b7c000
mprotect(0xb6b98000, 61440, PROT_NONE)  = 0
mmap2(0xb6ba7000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1b000) = 0xb6ba7000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libpcre.so.3", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0004\20\0\0004\0\0\0"..., 512) = 512
lseek(3, 426320, SEEK_SET)              = 426320
lseek(3, 426012, SEEK_SET)              = 426012
fstat64(3, {st_mode=S_IFREG|0644, st_size=427360, ...}) = 0
mmap2(NULL, 491604, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6b03000
mprotect(0xb6b6b000, 61440, PROT_NONE)  = 0
mmap2(0xb6b7a000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x67000) = 0xb6b7a000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0P\t\0\0004\0\0\0"..., 512) = 512
lseek(3, 8680, SEEK_SET)                = 8680
lseek(3, 8328, SEEK_SET)                = 8328
fstat64(3, {st_mode=S_IFREG|0644, st_size=9800, ...}) = 0
mmap2(NULL, 73912, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6af0000
mprotect(0xb6af2000, 61440, PROT_NONE)  = 0
mmap2(0xb6b01000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0xb6b01000
close(3)                                = 0
open("/lib/arm-linux-gnueabihf/libgpg-error.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0H\37\0\0004\0\0\0"..., 512) = 512
lseek(3, 61836, SEEK_SET)               = 61836
lseek(3, 61472, SEEK_SET)               = 61472
fstat64(3, {st_mode=S_IFREG|0644, st_size=62956, ...}) = 0
mmap2(NULL, 127064, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6ad0000
mprotect(0xb6adf000, 61440, PROT_NONE)  = 0
mmap2(0xb6aee000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0xb6aee000
close(3)                                = 0
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f63000
set_tls(0xb6f634c0, 0xb6f63c88, 0xb6f72050, 0xb6f634c0, 0xb6f72050) = 0
mprotect(0xb6e4f000, 8192, PROT_READ)   = 0
mprotect(0xb6aee000, 4096, PROT_READ)   = 0
mprotect(0xb6b01000, 4096, PROT_READ)   = 0
mprotect(0xb6ead000, 4096, PROT_READ)   = 0
mprotect(0xb6b7a000, 4096, PROT_READ)   = 0
mprotect(0xb6ba7000, 4096, PROT_READ)   = 0
mprotect(0xb6c75000, 4096, PROT_READ)   = 0
mprotect(0xb6c99000, 4096, PROT_READ)   = 0
mprotect(0xb6cca000, 4096, PROT_READ)   = 0
mprotect(0xb6ce1000, 4096, PROT_READ)   = 0
mprotect(0xb6d13000, 4096, PROT_READ)   = 0
mprotect(0xb6e7c000, 45056, PROT_READ)  = 0
mprotect(0xb6f28000, 8192, PROT_READ)   = 0
mprotect(0xb6f2b000, 20480, PROT_READ|PROT_WRITE) = 0
mprotect(0xb6f2b000, 20480, PROT_READ|PROT_EXEC) = 0
cacheflush(0xb6f2b000, 0xb6f30000, 0, 0x15, 0) = 0
mprotect(0xb6f3f000, 4096, PROT_READ)   = 0
mprotect(0x1e44000, 16830464, PROT_READ) = 0
mprotect(0xb6f71000, 4096, PROT_READ)   = 0
munmap(0xb6f67000, 28101)               = 0
set_tid_address(0xb6f63068)             = 2357
set_robust_list(0xb6f63070, 12)         = 0
rt_sigaction(SIGRTMIN, {sa_handler=0xb6e8c2b0, sa_mask=[], sa_flags=SA_RESTORER|SA_SIGINFO, sa_restorer=0xb6d426c0}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {sa_handler=0xb6e8c390, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART|SA_SIGINFO, sa_restorer=0xb6d426c0}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
ugetrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY}) = 0
brk(0x3b34000)                          = 0x3b34000
statfs("/sys/fs/selinux", 0xbea4e5cc)   = -1 ENOENT (No such file or directory)
statfs("/selinux", 0xbea4e5cc)          = -1 ENOENT (No such file or directory)
open("/proc/filesystems", O_RDONLY)     = 3
fstat64(3, {st_mode=S_IFREG|0444, st_size=0, ...}) = 0
read(3, "nodev\tsysfs\nnodev\trootfs\nnodev\tr"..., 1024) = 310
read(3, "", 1024)                       = 0
close(3)                                = 0
access("/etc/selinux/config", F_OK)     = -1 ENOENT (No such file or directory)
--- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0x884a59} ---
+++ killed by SIGSEGV +++
Segmentation fault
Similar to other reports all I get when running dockerd manually is "segmentation fault" and the logs report nothing interesting.
Docker version installed:
```root@raspberrypi:~# docker version
Client:
 Version:           18.09.0
 API version:       1.39
 Go version:        go1.10.4
 Git commit:        4d60db4
 Built:             Wed Nov  7 00:57:21 2018
 OS/Arch:           linux/arm
 Experimental:      false
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?```
Kernel info:
```Linux raspberrypi 4.14.71+ #1145 Fri Sep 21 15:06:38 BST 2018 armv6l GNU/Linux```
_Originally posted by @DutchessNicole in https://github.com/moby/moby/issues/29347#issuecomment-437581438_
