Zigbee discovery malfunction ("Gladys is not accessible"). Related to Node-red service change?
I need your help to fix a small issue in my Gladys-Zigbee-MQTT setup. Thanks in advance :wink:
The Zigbee devices already configured work fine, but I can no longer add new Zigbee devices. The « Zigbee Discovery Â» page (http://192.168.0.105/dashboard/integration/device/zigbee2mqtt/discover) shows the error « Gladys is not accessible Â». Yet all the indicators on the « Zigbee2mqtt service configuration Â» page (http://192.168.0.105/dashboard/integration/device/zigbee2mqtt/setup) are green.
The problem seems to coincide with a recent change: I switched from the Node-RED I initially set up (accessible at http://192.168..:1880) to the one now integrated into Gladys (accessible at http://192.168..:1881).
Could my issue be caused by that? What can I do to resolve it?
I should mention that the Zigbee page (http://192.168..:8080) is accessible, and that I was able to see the new Zigbee device I want to retrieve in Gladys displayed there.
I also notice from the page http://192.168.0.105/dashboard/integration/device/zigbee2mqtt/discover which shows this error « Gladys n’est pas accessible Â» that a click on the « Autoriser l’association Â» button does have an effect on the Zigbee service, because the notifications « Zigbee : allowing new devices to join Â» and « Zigbee : disabling new devices Â» are indeed displayed on the page http://___:8080
Hello. The problem has been known for a few days (latest zigbee2mqtt update). I think we’ll fix that on Monday (if we can do a Gladys release).
You have the details here Zigbee2mqtt 1.35 - Erreur affichage devices - #4 par cicoub13
Thanks @cicoub13. I had done some research but didn’t come across this topic.
So I’ll wait until it’s fixed.
Hello, I have never used Node-RED and I encountered the same problem again around noon today.
hello,
on Zigbee network discovery the same message also « Gladys is not accessible Â», while in the configuration and settings menus of the zigbee2mqtt integration everything is green!
but couldn’t the problem come from the koenkk/zigbee2mqtt container? it was apparently updated 6 days ago?
The error is mentioned here Zigbee2mqtt 1.35 - Erreur affichage devices - #4 par cicoub13
A fix has been made, now we just have to wait for the release.
FYI Gladys Assistant v4.34.0 was successfully deployed yesterday and I can confirm that it does fix the issue! :slight_smile:
Thanks @cicoub13 for the fix!
It’s not useful, but I confirm too :wink:. Thanks!
