Feat(external-integration): disconnect an oauth2 account
Hi @Lokkye :slight_smile:
I wanted to know where you were on this PR: feat(external-integration): disconnect an oauth2 account by callemand · Pull Request #2719 · GladysAssistant/Gladys · GitHub?
Is this still up to date?
Oops, I completely forgot about this feature. I’m working on it again.
Re @pierre-gilles
I just cleaned up, rebased, responded to code rabbit, and re-tested locally. Everything is fine on my side. You can review.
Thanks @Lokkye! :slight_smile: Review done here: External integrations: disconnect a linked account (oauth2 / account_link) by callemand · Pull Request #2719 · GladysAssistant/Gladys · GitHub
@pierre-gilles Thanks and correction made :slight_smile:
New review here: https://github.com/GladysAssistant/Gladys/pull/2719#pullrequestreview-5488990930
For info, to do a review, I just use Fable 5.1 High:
Which uses Anthropic’s « code-review » skill, which is excellent.
Thanks @pierre-gilles! Everything is fixed in the PR: container stop verification before deletion, Disconnect button proposed regardless of status, 409 during startup, and the small dots. I also ran the skill code-review before pushing, thanks for the tip :slightly_smiling_face: You can review it.
