Avis aux développeurs Gladys 4, j’ai besoin d’un coup de main pour finaliser mon environnement de dev.
Après avoir initialisé un environnement tout neuf (nodejs, sqlite3, openssl, openzwave, …), j’ai cette erreur lors du lancement des tests :
user@localhost:/mnt/d/Projets/Gladys/Sources/Gladys$ npm test
> gladys@4.0.0-alpha test /mnt/d/Projets/Gladys/Sources/Gladys
> run-p test-server test-front
> gladys@4.0.0-alpha test-server /mnt/d/Projets/Gladys/Sources/Gladys
> cd server && npm test
> gladys@4.0.0-alpha test-front /mnt/d/Projets/Gladys/Sources/Gladys
> cd front && npm test
> gladys-server@ pretest /mnt/d/Projets/Gladys/Sources/Gladys/server
> cross-env SQLITE_FILE_PATH=/tmp/gladys-test.db npm run db-migrate:test && npm run eslint
> gladys-front@ test /mnt/d/Projets/Gladys/Sources/Gladys/front
> jest --coverage
> gladys-server@ db-migrate:test /mnt/d/Projets/Gladys/Sources/Gladys/server
> cross-env NODE_ENV=test node_modules/.bin/sequelize db:migrate
Sequelize CLI [Node: 10.16.1, CLI: 5.4.0, ORM: 4.42.0]
Loaded configuration file "config/config.js".
Using environment "test".
ERROR: Please install sqlite3 package manually
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! gladys-server@ db-migrate:test: `cross-env NODE_ENV=test node_modules/.bin/sequelize db:migrate`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the gladys-server@ db-migrate:test script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /home/nicolas/.npm/_logs/2019-08-04T09_16_00_555Z-debug.log
npm ERR! Test failed. See above for more details.
npm ERR! errno 1
npm ERR! gladys@4.0.0-alpha test-server: `cd server && npm test`
npm ERR!
npm ERR! Failed at the gladys@4.0.0-alpha test-server script.
npm ERR! /home/nicolas/.npm/_logs/2019-08-04T09_16_00_592Z-debug.log
ERROR: "test-server" exited with 1.
Pourtant sqlite3 est installé et fonctionne :
user@localhost:/mnt/d/Projets/Gladys/Sources/Gladys$ sqlite3
SQLite version 3.22.0 2018-01-22 18:45:57
Enter ".help" for usage hints.
Connected to a transient in-memory database.
Use ".open FILENAME" to reopen on a persistent database.
sqlite> .exit
J’ai du loupé un truc, mais quoi ?
Merci d’avance pour votre aide…
