Gladys Assistant 4.72: Faster AI, Stabilized Homekit, and Many Fixes
Good evening everyone!
Gladys Assistant 4.72.0 is available :tada:
New Features
Zigbee: Support for double on/off for IKEA BILRESA button The IKEA BILRESA button is now fully supported via Zigbee2mqtt.
AI: Reduced latency and costs Images from cameras sent to the AI are now resized before sending, reducing latency and the cost of calls.
List of integrations: Adding tags Integrations are now tagged (local, cloud, Gladys Plus) to better identify their mode of operation.
ZwaveJS UI: Alpha release The ZwaveJS UI integration is now stable enough, the alpha warning banner is removed.
MQTT: Renaming the integration to « MQTT Virtual Devices » to simplify the understanding of this integration for users coming from Home Assistant.
Node-RED: Warning when deleting the container A warning message now alerts that deleting the Node-RED container also deletes all associated data.
Bug Fixes
Homekit: Fix for high CPU consumption related to mDNS A bug caused abnormally high CPU consumption. This is fixed by providing several mDNS options.
Nuki: Fix for processing Home Assistant discovery messages The Nuki integration was listening too broadly and continuously, which created performance issues if many Home Assistant-compatible devices were on the same broker.
CalDAV: Displaying errors in the configuration CalDAV configuration errors are now displayed directly in the interface.
Backup restoration: More robust Security has been enhanced in the Gladys Plus backup restoration function, notably through the use of execFile for OpenSSL commands.
User account creation: When creating a user account, the text above the « email » field is now clearer.
Zigbee2MQTT: Fix for a bug related to energy tracking Devices with energy tracking features are no longer permanently displayed in the « Discovery » tab.
Energy tracking: Fix for a bug when deleting a meter A bug occurred when a meter device was deleted in the Zigbee2mqtt integration. This is now fixed.
Matter: Fix for color management Use of a digital bitmap for optionsMask in Matter color control.
Thanks to all contributors of this version: @bertrandda, @cicoub13, and @David-Digitis
To update, you can wait 24 hours, or go to Settings > System > Update.
This weekend, I will be very available, so do not hesitate if you have any points to check, I will try to advance on the reviews of PRs :slight_smile:
Happy Easter weekend to everyone :house:
Thank you all!
And happy Easter and happy egg hunt!
:hatching_chick:
5 messages have been split to a new topic: Gladys restarts on startup
