I launched a small VM to test all this.
I started a container with the following parameters:
docker run -d \
# removed for readability
-v /var/lib/gladysassistant_other_folder:/var/lib/gladysassistant \
gladysassistant/gladys:v4
I added some logs, and I started a Zigbee2mqtt container, and here’s what it gives:
2022-03-07T18:55:44+0100 <info> installMqttContainer.js:25 (Zigbee2mqttManager.installMqttContainer) MQTT broker is being installed as Docker container...
2022-03-07T18:55:44+0100 <info> installMqttContainer.js:26 (Zigbee2mqttManager.installMqttContainer) Pulling eclipse-mosquitto:2 image...
2022-03-07T18:55:47+0100 <info> installMqttContainer.js:30 (Zigbee2mqttManager.installMqttContainer) Preparing broker environment...
basePathOnContainer: '/var/lib/gladysassistant',
basePathOnHost: '/var/lib/gladysassistant'
[ '/var/lib/gladysassistant/zigbee2mqtt/mqtt:/mosquitto/config' ]
2022-03-07T18:55:47+0100 <info> installMqttContainer.js:37 (Zigbee2mqttManager.installMqttContainer) Creating container...
2022-03-07T18:55:47+0100 <info> installMqttContainer.js:51 (Zigbee2mqttManager.installMqttContainer) MQTT broker is restarting...
The basePathOnHost is not correct, there is a bug in the basePath function
I am investigating…
