Hi @prohand … EDIT: Oh wait, it’s @bertrandda!
I’m having trouble connecting with Infomaniak for the CALDAV integration (I’ve checked, the password is correct). It works perfectly with the internal integration … which is deprecated.
Here are the logs:
[2026-11-29T19:33:34.856Z] [INFO] onCalendarAccountUpdated <- stephane
[2026-11-29T19:33:35.294Z] [ERROR] [scheduler] stephane: CalDAV sync failed Error: CalDAV discovery failed: Invalid credentials: PROPFIND https://sync.infomaniak.com/ returned 401 Unauthorized
at SyncManager.createCalDavClient [as createClient] (file:///app/src/caldav.js:170:11)
at process.processTicksAndRejections (node:internal/process/task_queues:104:5)
at async SyncManager.runPass (file:///app/src/scheduler.js:200:22) {
[cause]: Error: Invalid credentials: PROPFIND https://sync.infomaniak.com/ returned 401 Unauthorized
at fetchPrincipalUrl (file:///app/node_modules/tsdav/dist/tsdav.mjs:2083:39)
at async findPrincipalUrl (file:///app/node_modules/tsdav/dist/tsdav.mjs:2141:20)
at async createAccount (file:///app/node_modules/tsdav/dist/tsdav.mjs:2158:37)
at async DAVClient.login (file:///app/node_modules/tsdav/dist/tsdav.mjs:2540:37)
at async SyncManager.createCalDavClient [as createClient] (file:///app/src/caldav.js:168:5)
[2026-11-29T19:33:41.719Z] [INFO] Action sync_now
[2026-11-29T19:33:42.110Z] [ERROR] [scheduler] stephane: CalDAV sync failed Error: CalDAV discovery failed: Invalid credentials: PROPFIND https://sync.infomaniak.com/ returned 401 Unauthorized
Wouldn’t it be possible to “migrate” what we already have in the internal integration to the external one?
