External integration - Govee
Hello, for some time now, my Govee lamp no longer responds in scenes and keeps disconnecting before reconnecting.
Do you have any idea?
Have a great day
Example logs
[2026-11-24T02:55:36.415Z] [INFO] [govee] H6076 at 192.168.1.180 stopped answering on the LAN
[2026-11-24T02:56:06.418Z] [INFO] [govee] H6076 at 192.168.1.180 answers on the LAN
[2026-11-24T03:00:36.434Z] [INFO] [govee] H6076 at 192.168.1.180 stopped answering on the LAN
[2026-11-24T03:01:06.438Z] [INFO] [govee] H6076 at 192.168.1.180 answers on the LAN
[2026-11-24T03:03:06.445Z] [INFO] [govee] H6076 at 192.168.1.180 stopped answering on the LAN
[2026-11-24T03:03:36.446Z] [INFO] [govee] H6076 at 192.168.1.180 answers on the LAN
[2026-11-24T03:05:06.453Z] [INFO] [govee] H6076 at 192.168.1.180 stopped answering on the LAN
[2026-11-24T03:05:36.453Z] [INFO] [govee] H6076 at 192.168.1.180 answers on the LAN
[2026-11-24T03:13:06.486Z] [INFO] [govee] H6076 at 192.168.1.180 stopped answering on the LAN
[2026-11-24T03:13:36.490Z] [INFO] [govee] H6076 at 192.168.1.180 answers on the LAN
[2026-11-24T03:21:06.518Z] [INFO] [govee] H6076 at 192.168.1.180 stopped answering on the LAN
[2026-11-24T03:21:36.519Z] [INFO] [govee] H6076 at 192.168.1.180 answers on the LAN
[2026-11-24T03:23:06.527Z] [INFO] [govee] H6076 at 192.168.1.180 stopped answering on the LAN
[2026-11-24T03:23:36.528Z] [INFO] [govee] H6076 at 192.168.1.180 answers on the LAN
[2026-11-24T03:26:06.540Z] [INFO] [govee] H6076 at 192.168.1.180 stopped answering on the LAN
[2026-11-24T03:27:06.544Z] [INFO] [govee] H6076 at 192.168.1.180 answers on the LAN
[2026-11-24T03:47:06.622Z] [INFO] [govee] H6076 at 192.168.1.180 stopped answering on the LAN
[2026-11-24T03:48:06.625Z] [INFO] [govee] H6076 at 192.168.1.180 answers on the LAN
[2026-11-24T04:26:06.773Z] [INFO] [govee] H6076 at 192.168.1.180 stopped answering on the LAN
[2026-11-24T04:27:06.779Z] [INFO] [govee] H6076 at 192.168.1.180 answers on the LAN
```[2026-11-24T04:30:36.791Z] [INFO] [govee] H6076 at 192.168.1.180 stopped answering on the LAN
[2026-11-24T04:31:06.793Z] [INFO] [govee] H6076 at 192.168.1.180 answers on the LAN
[2026-11-24T04:35:36.809Z] [INFO] [govee] H6076 at 192.168.1.180 stopped answering on the LAN
[2026-11-24T04:36:36.812Z] [INFO] [govee] H6076 at 192.168.1.180 answers on the LAN
[2026-11-24T05:47:07.073Z] [INFO] [govee] H6076 at 192.168.1.180 stopped answering on the LAN
[2026-11-24T05:47:37.072Z] [INFO] [govee] H6076 at 192.168.1.180 answers on the LAN
@JKBS64 Hi! According to your logs, the lamp leaves three consecutive status requests unanswered (i.e., 90 seconds) several times per hour, then comes back. The integration just notes this: it’s the lamp that goes silent on the local network. A few questions to find out where this comes from:
  1. Since when? Has there been an update to the lamp in the Govee app, or a change in the box or Wi-Fi?
  2. Have you entered a Govee API key in the configuration (to switch to the cloud when the local network doesn’t respond)?
  3. In a scene that doesn’t work, what exactly happens: nothing at all, or an error message?
On my side, I will make the integration more tolerant of these short silences, so that it no longer marks the lamp as “unreachable” each time.
Hi @guim31
  1. I might get scolded, but I’ve noticed that it’s been acting up since the version before last of Gladys Assistant. I’m not saying there’s a connection :wink: .
  2. Yes, since yesterday, but it doesn’t change anything
  3. Nothing happens.
  4. Plus, when I turn on the lamp via the switch in Gladys, it turns off after a while (a few minutes).
@JKBS64 thanks, point 4 is the most telling: a lamp that turns off by itself after being turned on from Gladys is not normal. I’ll check what could be sending it the “off” command (and what has changed on Gladys recently), as well as the disconnections. I’ll get back to you with a version to test.
