Individual ENEDIS token link
I just got a free token for 3 years via Conso API …Conso API - Documentation
How to use it, without using Gladys?
Hi @JPPUYB and welcome to Gladys :slight_smile:
We don’t support this service in Gladys, to retrieve your electricity consumption, 2 options are possible:
A suggestion: if the individual ENEDIS link is not supported, please specify this in the online documentation.
Thank you
I’m not sure I understand your feedback? :smiley:
The online documentation for ENEDIS Integrations states:
« This API is only offered to companies after signing a contract and completing a certification process. »
However, ENEDIS allows for individual sharing: specify in this documentation that this is not supported, regardless of the reason.
This sharing option is visible on the ENEDIS account, which is why I took this step. I even received a notification of acceptance.
Since then, I have terminated this with a notification…
Best regards
Did you manage to get the Enedis connection working on Gladys Plus? :slight_smile:
I am online with ENEDIS to check for data scam.
ENEDIS result: this site https://conso.boris.sh is reliable, the return email addresses are indeed from ENEDIS.
In the end, this function of sharing data on an individual basis does exist.
I will test Gladys Plus.
Hello, is it planned to implement compatibility for this API? If not, how is it possible to sponsor this project?
Thank you very much!
Hello and welcome to Gladys!
The integration of this third-party service is not planned, as Gladys Plus already offers a native and well-established Enedis integration directly in the interface :blush:
To support the project, the best way is to upgrade to Gladys Plus! You can also star it on GitHub, talk about it, or leave a review if you’re already using the solution.
Thanks for your support!
