I can retrieve the stream from my camera via the classic « Camera » integration with the RTSP stream, but I can’t find my camera via the Reolink integration.
The admin account with the password is correct because I use it to retrieve my RTSP stream, and I entered the camera’s IP address to help it find it, but nothing happens.
The « Too Many Requests » error is not the cause of the problem: it’s just Gladys limiting the frequency of network scans, and your manually entered IP address is indeed tested despite that.
The most likely cause: the HTTP server of your camera is disabled. This is the default setting on recent Reolink firmwares. RTSP is sufficient for the « Camera » integration, but the Reolink integration needs HTTP (or HTTPS) to communicate with the camera. That’s why your RTSP stream works while the camera is not found.
To enable it, in the Reolink app:
Settings → Network → Advanced → Server Settings, then enable:
HTTP (or HTTPS): essential;
RTSP: already done on your end, for live video;
ONVIF: so that detections (motion, person, vehicle…) arrive instantly.
Then, in Gladys:
Update the Reolink integration to 1.4.1. It now clearly shows when a camera does not respond in HTTP, instead of silently ignoring it.
Click on Test the connection.
Launch a scan from Discovery.
If it still doesn’t work, send me the logs from 1.4.1: they will precisely indicate why the camera is not responding.
If you ever discover anything else, or if something is missing, let me know and I’ll add it.
I only have one camera model, so it’s not easy to integrate everything right away.
Hello @Will_71, I just noticed that at night it keeps the light on permanently… and it sets the camera position all the way to the left. Even if I manually turn off the light, with a refresh rate set to 30 seconds, the light turns back on. And by removing my camera from the integration, it no longer does that.
The integration only sends commands to the camera when Gladys requests it: the refresh only reads the state and takes a picture. To find out what triggers it, you can give me:
The logs of the Reolink integration for a few minutes while the light turns back on (Integrations → Reolink → logs). I’m looking for lines like floodlight set to 1 or ptz_move set to 1.
Is there a scene that uses this camera, its light, or its movements? Or a scene that turns on lights at dusk?
Have you turned on the light from Gladys? And when you turn it off „manually“, is it from Gladys or from the Reolink app?
In the Reolink app, what is the mode of the floodlight (lighting / alert, schedule)? If you see a schedule from 00:00 to 23:59, it was set by the integration; put your usual setting back.
Does the camera move to the left in small jerks or all at once?
“Motion detected” means that the camera itself is reporting movement every ~30 s: the integration just relays what it reads. And no line like floodlight set to … or ptz_move set to … in your logs: Gladys hasn’t sent any command, neither to the light nor to the PTZ.
This matches everything you describe: the projector turns on when motion is detected and stays on for at least 30 s, so a detection every 30 s keeps it on continuously; and the automatic tracking makes the camera pivot toward what’s moving, here to the left. At night, it’s often an insect attracted by the light, a spider web, a branch, or an infrared reflection.
To be sure, in the Reolink app, check the list of nighttime alarms/recordings: if you see motion detections every 30 s, it’s the camera generating them.
If the Reolink app shows nothing while Gladys says “Motion detected,” get back to me: that would mean the integration’s reading is wrong, and I would keep looking.
