Update on my 24 integrations: audit, fixes and new versions (7 and 8 October)
Here’s what happened over the past two days on my 24 external Gladys integrations. There have been many changes. Don’t forget to update from the store.
:wrench: Tuesday, October 7: Common Bases
On all 24 repositories:
  • Automatic manifest verification on each pull request, with the same checks as the Gladys store. A manifest error is thus detected before publication.
  • Dependabot enabled: GitHub actions and the Docker image are automatically updated.
  • A GitHub Release for each version, with its changelog, to easily track what changes.
Frequent fixes:
  • Widgets that no longer displayed anything: Gladys now waits a maximum of 15 seconds. Beyond that, the widget remained broken until the page was reloaded. Now, the widget always responds in time (Air Quality, UV Index, Pollen, Forecast.Solar, Proxmox, PBS, TCL, VigiEau, TV Guide).
  • Clearer connection status: it indicates what’s wrong, instead of « disconnected » (NUT, Proxmox, PBS, Electricity Maps, LG ThinQ).
New features:
  • Mammotion: widget, scene triggers and actions (Gladys 5.1).
:magnifying_glass_tilted_left: Wednesday, October 8: A Complete Audit
Each repository was audited. Common points:
  • Node 22 minimum, tests on Node 22 and 24, and Docker image built on each pull request.
  • Stricter image (npm ci, pinned base image for some integrations).
  • Node 26 was tested, then we reverted to Node 24 pending Node 26 becoming LTS.
  • Documentation (EN/FR) and changelogs updated.
Main points, integration by integration:
  • Apple Device Tracker: clean recovery after an iCloud failure, without multiplying connections on the account
  • Broadlink: IR/RF codes sent only once, codes published as buttons (no longer as switches), codes.json file protected against corruption
  • Daikin Cloud: API quota better protected, failed reads reported, sessions preserved
  • Devmel AirSend: timed shutter stopped on time even in case of error, orders not replayed by mistake, service restarted only after several failures
  • Electricity Maps: faster retry, respect of Retry-After, fewer duplicates in history
  • Forecast.Solar: quota respected, coordinates hidden, less history
  • Home Connect: quota saved, recovery after a failed startup, refreshed token preserved
  • Host Supervision: measurements continue even if Gladys or the host has an issue
  • LG ThinQ: pause when Gladys is away, quota protected on forced reads
  • Mammotion: refusal of a second mowing launch in preparation, session errors better recognized
  • NUT (UPS): more robust reads, status grouped on all servers
  • Olvid: each call to the daemon is time-limited, session preserved during Gladys reconnections
  • Pollen: one request per cycle, new attempt in case of network outage, sends limited to not exceed Gladys’ quota
  • Fuel Prices: dates in Paris time, search kept for 5 minutes, distance removed from device parameters
  • TV Guide: more reliable guide download, widget and status fixed
  • Proxmox VE: maximum delay for each request, one VM list read per cycle
  • Proxmox Backup Server: time-limited requests, certificate pinning possible, removed datastores removed
  • Air Quality: retries, Open-Meteo reads grouped, safer location editor
  • Synology: NAS with self-signed certificates work again, certificate pinning possible
  • TCL Lyon: schedules in Lyon time, new device read immediately
  • UV Index: retries, last value kept as a backup, hourly cache, grouped reads
  • VigiEau: refresh, location list and logs strengthened
  • Yoto: refused token refreshed, new attempt on startup, less frequent queries
  • Z2M Devices Monitor: TLS with a private certification authority, broker outages tolerated, backup maintained even if Gladys is down
:rocket: Next: New Plugins, and I Need You
Pierre-Gilles kindly offered me a Team Premium seat. A big thank you to him :folded_hands:
Thanks to this, I will develop other plugins for Gladys.
To choose the next ones, I will pick from this topic: Most Popular Home Assistant Integrations: Candidates for Gladys External Integrations
Don’t hesitate to share your opinion or vote for those that interest you. This will help me choose the order.
But I won’t necessarily have all the equipment at home. I will therefore need testers:
  • If you have one of the devices or services from this list, let me know here.
  • If you want to test a version before its release, reply to this topic indicating your hardware.
  • Feedback on existing integrations (bugs, ideas) is also welcome, on the forum or on GitHub.
Thank you all for your feedback. It’s what drives these integrations forward :blush:
Hi @prohand, well done for all these integrations and your very high reactivity to the feedback given!
So I’m throwing a few stones in the pond at you :wink:
  • Tesla Powerwall (gen3) plugin → I can test
  • Onkyo (amplifier) plugin → I can test
  • Dyson (fan and maybe robot like the matterbridge plugin) → I can test
  • Ecovacs (lawn mower and Deebot cleaning robots) → I’ll be able to test the lawn mower
  • Beatbot (pool robot) → I’ll only be able to test it in the bathtub now :rofl:
  • Téléinformation plugin, I have this module Lixee TIC Rail DIN that I monitor with teleinfo2mqtt currently
  • RFPlayer → I can test
You don’t have to do everything, you know :sweat_smile:, I’ll try a simple one on my side but not before a few weeks unfortunately.
Hi, regarding the TV guide, the widget used doesn’t allow changing the dashboard with a left/right swipe on mobile.
The widget’s surface seems to block this gesture :slight_smile:
I tested on my side and I don’t have the problem
Does anyone else encounter this type of problem?
If possible, for bugs in integrations, creating an issue directly on GitHub or directly on the integration post on the forum would be great :wink:
I risk not being able to keep up with all the plugins I will make in the future, knowing that I already have none :sweat_smile:
Thanks for the compliments :wink:
I’ll see if I can do some of them over the weekend :wink:
Is there one among all those you indicate that would be a priority?
that would be teleinformation, thanks in advance :smiling_face:
Minor correction, it’s a Tesla Wall Connector gen3 that I have, not a Powerwall :confused:
I launched Teleinfo :wink:
Téléinfo: Teleinfo : votre compteur Linky dans Gladys avec le module LiXee TIC
I’ve started Dyson and Ecovacs :wink:
Dyson ready: Intégration - Dyson
Ecovacs ready: Intégration - Ecovacs
For the wall connector, @guim31 took care of it :slight_smile:
Yes, I saw it, thank you :smiling_face:
Onkyo ready: Intégration - Onkyo
@prohand I’m having trouble following :rofl:
Beatbot ready: Intégration - Beatbot
And here it is @NineStars everything is developed :slight_smile:
The last one: https://community.gladysassistant.com/t/integration-rfplayer/
All I have left to do is test everything (well, what’s left), and damn, it’s clearly taking longer than developing :hot_face:
