I’m sharing a small project I use at home: a bridge between a Panasonic Aquarea heat pump and Gladys, via the native MQTT integration. No development in Gladys is required.
What it does
- Reading: outdoor temperature, water pressure, heating and boiler temperatures and setpoints, on/off states, Eco/Comfort presets, silent mode, errors, consumption (day/month/12 months, with cost).
- Control from Gladys: heating and boiler on/off, setpoints, Eco, Comfort.
- Safeties: control disabled by default (commands are only logged), setpoints bounded, no command replayed.
A screenshot of the Gladys dashboard is in the README.
What you should know before trying it
- Unofficial project, with no link to Panasonic or Gladys. It sends real commands to a real heat pump: use at your own risk.
- It goes through the Panasonic cloud (Aquarea Smart Cloud): you need internet and your Panasonic account. A local mode (like HeishaMon) is considered, but nothing is promised.
- Tested on a WH-WXG09ME8 with a CZ-TAW1B adapter, a heating zone and a boiler. Elsewhere, it may differ, and your feedback interests me.
- Panasonic requires a confirmation code on the first connection (the procedure is in the README).
Installation: Docker Compose, an MQTT broker, a few environment variables. The README (in French and English) explains the steps and the configuration on the Gladys side.
Repository (MIT license): GitHub - alejantu/gladys-aquarea-mqtt-bridge: Aquarea Smart Cloud <-> MQTT bridge for Gladys Assistant (read and control a Panasonic Aquarea heat pump). · GitHub
Feedback, questions, and ideas are welcome, here or on GitHub.
