I would like to set up the start of an alarm or at least home monitoring when the occupants leave the house. I’m a beginner and I don’t even know what to buy.
I have Aqara presence detectors, a Tapo TC71 camera, and Hues. That’s all for now.
What do you recommend for an outdoor camera? A siren (mandatory or not?) Opening sensors? I understand that I need Zigbee or Matter, but from which brand?
I would also like not to have to « lock » the house. I know myself… I will leave the house without arming anything… Is this possible with phones? Or Nut or others? What integrations do you recommend?
You already have the basic equipment to make good scenarios.
Tapo camera is good, personally I recommend wired if possible (Wi-Fi jammers are common) then I even have old Yi cameras and they work well. For outside I have no advice (personally I would replace mine with a reolink duo).
However, I recommend Frigate as NVR (you will be able to manage presence via your cameras in gladys and video recordings in frigate).
Opening sensor is a nice to have. Maybe for the exterior doors in case they are broken down.
The alarm is not mandatory. Personally, I think I will take a zigbee one. I would like feedback here from people who have one.
Arm the alarm when the house is empty: LanManager and phone is ok. That’s what I do.
Nuts with bluetooth I stopped, it worked average (when the accommodation is large).
My personal scenes:
Activate the alarm when the house empties (based on phones)
When the alarm is activated, I activate all the cameras via Frigate
When the alarm is active, I test the states of the presence sensors + Frigate camera detection to send a message, trigger the flashing of the lights …
When the alarm is deactivated, I turn off the « indiscreet » cameras (toilet, bathroom, bedroom … )
Then I also have messages at night when the alarm is deactivated on some of my sensors. Maybe a better way to do it would be to use partial activation at night when you are at home (avoid turning on an alarm but send a discreet message).
Your answer already gives me a bit of direction. Indeed, I bought some Chipolo Bluetooth trackers… probably too smart… impossible to find them. So I’ll try with the phones. That’s the problem when you don’t know anything: finding the right associations without creating overly complicated systems
Since it works for you, I’ll try to do the same thing at my place! So I have some work to configure Lanmanager and the phones as well as Frigate
