I’m passionate about gardening/computers.
I have been aware of Gladys for quite some time, without ever taking the plunge, I admit that if we could associate a Zigbee gateway without going through Smart life, I would take the plunge since it’s part of it, I’m starting my installation (Zigbee door sensor, Zigbee switch + motion detector).
This is considered based on what you want to install. Most Zigbee mains-powered devices (plugs, bulbs, switches, sirens, etc.) also act as relays. As a result, it creates a fairly effective mesh network!
I discovered that there are USB Zigbee repeaters to relay the network.
In addition to devices that also act as routers (basically anything that’s plugged into power), which could surely help you in your case.
Not to mention that, depending on the adapters, you can go well beyond 20 — more like 100+ devices.
