I checked this morning to see if I could do something about it, but it’s not as simple as that.
The nupnpsearch API has changed in version 4 of the node-hue-api module we use, and no longer returns the serial number, which we used until now as a unique identifier to identify the bridge through Gladys.
Switching to a mix of nupnp + upnp is not a simple change, it’s a real development that requires testing with real equipment (which I don’t have). I’ll probably break more than I fix if I do this blindly ^^
If anyone has Philips Hue equipment and wants to help @Tlse-vins with his problem, I’m available if there are any questions about the current integration
Sorry @Tlse-vins, I know it’s frustrating I’d like it to work for everyone as much as you do, and I’d like there to be more contributors on the integrations just as much ^^
In my opinion, all the devs on the forum have been on the terrace since the deconfinement
I didn’t follow the whole topic, but I just tested the Hue integration on the instance I’m setting up in production at home (without Docker).
And I notice an issue, when I connect my lights, everything works, I put them on the dashboard, and then after a few moments, they disappear and I have to reconnect them via the integration page.
Edit: Well, after several hours, it hasn’t happened again.
It seems strange to me, did you really add the lamps to Gladys? Maybe the addition didn’t actually work?
I’m surprised that lamps are disappearing
By the way @Jean-Philippe, if you ever want to help @Tlse-vins, we are looking for someone who has Philips Hue and could help implement a double scan that does both N-UpnP search and UpnP search at the same time
It’s quite a simple thing to implement, but I don’t have Philips Hue and I can’t test it!
On my side, I live in Indonesia, it will cost more in shipping than in materials
In any case, as I explained in another post recently, I already have a lot of work on the core, it’s not realistic for me to handle integrations in addition, I prefer that there are referents on each integration
I’m bringing this topic up again because I still have the problem detecting the Hue bridge.
That would save me from having to flash my Zigbee USB stick, because I’ve reached the 40-device limit due to the bulbs.
