Checconio's review of Gladys Assistant 5
Hi @Checconio,
Following up on your message here:
I prefer to answer in a different topic to avoid cluttering the main topic :slight_smile:
I made a fix in a PR, and I have a Gladys Plus URL to share with you: https://claude-bug-3031-3on61t.gladys-plus.pages.dev/, can you confirm that it fixes the issue for you? You just need to log in with your usual Gladys Plus credentials :wink:
Thanks for the quick response @pierre-gilles, I can confirm that the dashboard menu issue is fixed in the PR :slight_smile:
Thanks for your quick response, I’ll merge and it will go out today in a 5.0.1 :wink:
@Checconio Second bug fixed, the decimal values to check, can you test here: https://claude-bug-3041-ijnmw0.gladys-plus.pages.dev/ ? :slight_smile:
Sorry, I hadn’t seen it but yes all good :slight_smile:
