@pierre-gilles, @AlexTrovato, @VonOx,
I’m following up on this topic as I consider it potentially critical on some rather heavy instances.
As a reminder, the discussion topics:
If we can define the complete roadmap as well as validate a specification, I’m willing to take care of it as much as possible and produce a first draft quickly.
Also as a reminder, the proposal I made (modified according to Pierre-Gilles’s suggestion in order) to start the discussion:
1st PR :
- Front-end side :
- a selection field on each feature “Conserver l’historique des états de la feature” offering the same choices as in the Settings/System tab,
- The field is selected by default on Gladys’s general configuration (except for cameras
- Server side :
- The column « keep_history » is already present so nothing to do on that side
- Either :
- we add a “delay_keep_history” column to the t_device_feature table defaulting to Gladys’s general config ?
- or we modify the “keep_history” column to be able to put the value directly ?
- or we use a device parameter for example:
if present then we take this parameter into account for the feature values, otherwise we take Gladys’s general parameter as today.{ "name": "[FEATURE_SELECTOR]_HISTORY_IN_DAYS", "value": [Delay en jours] } - review destroy_states according to this parameter.
- Front-end side :
2nd PR :
- Front-end side :
- a checkbox on each feature “Enregistrer uniquement les changements d’états”,
- this checkbox is unchecked by default to remain as it is now,
- Server side :
if the checkbox “Enregistrer uniquement les changements d’états” is checked, either :
- we add an “only_keep_value_changes” column in the t_device_feature table, this is 0 by default,
- or when checked we add a parameter in device_param :
{ "name": "[FEATURE_SELECTOR]:only_keep_value_changes", "value": true } -
if the value of this parameter is true and the new value is the same as the previous one, we go through a new file server/lib/device/device.saveLastStateChanged.js to record in the table t_device_feature the
saveLastStateChangedas you asked me at the time of the Netatmo development :
- Front-end side :
Code Proposal
const db = require('../../models');
const logger = require('../../utils/logger');
const { EVENTS, WEBSOCKET_MESSAGE_TYPES } = require('../../utils/constants');
* @description Save new device feature state in DB.
* @param {Object} deviceFeature - A DeviceFeature object.
* @example
* saveLastValueChanged({
* id: 'fc235c88-b10d-4706-8b59-fef92a7119b2',
* selector: 'my-light'
async function saveLastStateChanged(deviceFeature) {
// logger.debug(`device.saveLastStateChanged of deviceFeature ${deviceFeature.selector}`);
const now = new Date();
// save local state in RAM
this.stateManager.setState('deviceFeature', deviceFeature.selector, {
last_value_changed: now,
await db.sequelize.transaction(async (t) => {
// update deviceFeature lastValue in DB
await db.DeviceFeature.update(
where: {
transaction: t,
// send websocket event
this.eventManager.emit(EVENTS.WEBSOCKET.SEND_ALL, {
type: WEBSOCKET_MESSAGE_TYPES.DEVICE.NEW_STATE_NO_CHANGED,
payload: {
device_feature_selector: deviceFeature.selector,
module.exports = {
saveLastStateChanged,
- When the value changes again, we go back through the function in server/lib/device/device.saveState.js which we must modify to re-save, before the new value, the previous value already in the database, to have an adjusted curve :
Code Proposal
const { BadParameters } = require('../../utils/coreErrors');
const DEFAULT_OPTIONS = {
skip: 0,
order_dir: 'DESC',
order_by: 'created_at',
* @param {number} newValue - The new value of the deviceFeature to save.
* @example
* saveState({
* }, 12);
async function saveState(deviceFeature, newValue) {
if (Number.isNaN(newValue)) {
throw new BadParameters(`device.saveState of NaN value on ${deviceFeature.selector}`);
const optionsWithDefault = Object.assign({}, DEFAULT_OPTIONS);
// logger.debug(`device.saveState of deviceFeature ${deviceFeature.selector}`);
const previousDeviceFeature = this.stateManager.get('deviceFeature', deviceFeature.selector);
const previousDeviceFeatureValue = previousDeviceFeature ? previousDeviceFeature.last_value : null;
const previousDeviceFeatureLastValueChanged = previousDeviceFeature ? previousDeviceFeature.last_value_changed : null;
const deviceFeaturesState = await db.DeviceFeatureState.findOne({
attributes: ['device_feature_id', 'value', 'created_at'],
order: [[optionsWithDefault.order_by, optionsWithDefault.order_dir]],
where: {
device_feature_id: deviceFeature.id,
const previousDeviceFeatureStateLastValueChanged = deviceFeaturesState ? deviceFeaturesState.created_at : 0;
last_value: newValue,
where: {
// if the deviceFeature should keep history, we save a new deviceFeatureState
if (deviceFeature.keep_history) {
// if the previous created deviceFeatureState is different of deviceFeature
// last value changed, we save a new deviceFeatureState of old state
if (previousDeviceFeatureLastValueChanged - previousDeviceFeatureStateLastValueChanged > 0) {
await db.DeviceFeatureState.create({
value: previousDeviceFeatureValue,
created_at: previousDeviceFeatureLastValueChanged,
value: newValue,
type: WEBSOCKET_MESSAGE_TYPES.DEVICE.NEW_STATE,
payload: {
// check if there is a trigger matching
this.eventManager.emit(EVENTS.TRIGGERS.CHECK, {
type: EVENTS.DEVICE.NEW_STATE,
device_feature: deviceFeature.selector,
previous_value: previousDeviceFeatureValue,
module.exports = {
saveState,
Example :
if we receive data for a consumed power
value: 1014.7,
created_at: 2022-04-19 04:20:13.277 +00:00
value: 1014.9,
created_at: 2022-04-19 04:30:13.277 +00:00
value: 1014.9,
created_at: 2022-04-19 04:40:13.277 +00:00
value: 1014.9,
created_at: 2022-04-19 04:50:13.277 +00:00
value: 1014.9,
created_at: 2022-04-19 05:00:13.277 +00:00
value: 1014.9,
created_at: 2022-04-19 05:10:13.277 +00:00
value: 78.0,
created_at: 2022-04-19 05:20:13.277 +00:00
In the DB we will find only
value: 1014.7,
value: 1014.9,
// here we did not save the identical values
value: 1014.9,
// After writing the value below, we sent again
value: 78.0,
Question: Is it useful or necessary to see anything for aggregated data? Let me explain: following lmilcent’s post (previously cited regarding retention), during the 1st PR we must take this into account so as not to break data aggregation if the feature’s keep_history is set to 1 day. The 1-year aggregation should still keep all its data unless keep_history is set to « OFF », right??
