Configuration Moes ZM-1P100M-M-MS Tuya/Zigbee
Dear Geek and Gladys Expert Friends
Here’s a bone to chew on that I’ve already chipped a few teeth on, but I’m learning and I have room for improvement
I tried an external configuration of a ZM-1P100M-M-MS (TZE28C1000000_2fnssffc to be exact) in Zigbee
I found this source [New device support]: MOES ZM6LT1 1-Phase Energy Power Meter With Current Transformer Sensor Clamp · Issue #32416 · Koenkk/zigbee2mqtt · GitHub
I applied the latest version, I have data feedback.
I have two devices. One at the output of my BEEM-ON 500w (self-consumption) and the other at the input of my circuit breaker (overall house consumption)
My question. Who has already dealt with this device and does the configuration seem relevant?
My doubts: Apart from the voltage, I’m not sure about the accuracy of the other information…
Thank you :slightly_smiling_face: :upside_down_face:
Hi Olivier,
Good news: you shouldn’t need an external converter anymore :slightly_smiling_face:
Your meter (I assume the exact ID displayed in Zigbee2mqtt is _TZE284_2fnssffc) is natively supported by Zigbee2mqtt since version 2.13.0, under the name Moes ZM6LT1. This is the issue code you found, officially integrated via this PR. And since v5.1.4, Gladys includes Zigbee2mqtt 2.14.2.
What I propose
  1. Check the version of Gladys and that of Zigbee2mqtt (Z2M interface > Settings > About).
  2. Remove the external converter, then restart Zigbee2mqtt.
  3. In the device page in Z2M, verify that it appears as « Moes ZM6LT1 », natively supported.
  4. In Gladys, restart Zigbee2mqtt discovery and update the device to retrieve the correct features.
The exposed measurements
  • energy: consumed energy index (in the direction of the clamp)
  • reverse_energy: energy index in the reverse direction (injected)
  • voltage, current, power, ac_frequency
On the Gladys side, voltage, current, power, and the energy index are taken. reverse_energy, active_energy, and frequency are not yet reported.
Common pitfalls that distort measurements
  • The clamp must surround a single conductor (the phase), not the entire cable. If it surrounds the phase and the neutral, the two currents cancel each other out, and you will read a current and power close to 0. This was exactly the problem of the person in the GitHub issue.
  • The direction of the clamp: the arrow must point in the direction of the current you want to measure (from the grid to the house for the general, from the BEEM to the house for production). If it is reversed, the energy accumulates in reverse_energy instead of energy.
  • Power and current have no sign. On the main meter, if your BEEM produces more than what the house consumes at that moment, you will still see a positive power even though you are injecting. Only the energy / reverse_energy indices allow you to know the direction of the current.
To verify if the values are correct
  • Turn on a known load (e.g., a 2000 W kettle): on the main meter, power should increase by approximately 2000 W and current by approximately 2000 / 230 ≈ 8.7 A.
  • Check that power ≈ voltage × current (approximately, the power factor comes into play).
  • Compare the BEEM meter with the production displayed in the BEEM app, and the index of the main meter with the evolution of your Linky over a day.
If something is still wrong after that, can you share:
  • your versions of Gladys and Zigbee2mqtt,
  • a screenshot of the « State » tab of each of the two devices in Zigbee2mqtt,
  • the values you expected at the same time (BEEM app, Linky…) ?
We can then precisely see which measurement is incorrect.
Hi Cicoub
Thanks for your reply, for your long detailed reply!
It comes at a good time, as I just received an order for modules to redo the mesh of my house. An old house with thick walls… it’s a bit of a hassle. So I’m going to start from scratch to get a nice clean mesh.
Thanks for your involvement.
I have checked the versions, removed the external conv, restarted the discovery, but no it remains in « </>generated support »
It’s a _TZE28C1000000_2fnssffc
Thanks Olivier for your feedback!
« Generated support » means that Zigbee2mqtt does not recognize the device ID and manages it generically. So I need to see exactly what it reports.
Can you share:
  1. The exact versions of Gladys and Zigbee2mqtt (Z2M > Settings > About).
  2. A screenshot of the « About » tab of the device in Z2M, with the Zigbee Model and Zigbee Manufacturer fields visible. The best is to copy and paste them here as text. The ID _TZE28C1000000_2fnssffc seems odd to me, I want to make sure there is no reading error.
  3. A screenshot taken after your changes: the one you posted is from 10/19, so before the converter was removed.
Did you also restart Zigbee2mqtt after removing the converter? If so, you can try removing the device from Z2M and then re-pairing it.
Thanks!
Hi @Olivier.L57, with Gladys 5.3.6, a device in « generated support » now appears at the bottom of the Discovery tab, under « Not supported by Zigbee2MQTT ». You can add it there with the generic functions that Zigbee2MQTT has deduced, and the « Copy information » button gives the exact model and manufacturer: you can paste them here, that will answer my previous question. Details: Gladys Assistant 5.3.6: follow Zigbee pairing live, and edit your dashboard from your phone 🐝
Thanks Cicoub :slightly_smiling_face:
