Trouble pairing a LiXee with my Linky meter
Hello, I recently purchased a ZLINKY_TIC_V2, and I can’t pair this device.
The Linky is 20 meters away from the Raspberry receiver on a SONOF dongle with a small antenna.
I do radio, and I have coaxial adapters and extensions, which allowed me to change the antenna on the LIXEE. I also installed a ZigBee bulb (gateway) right next to the LIXEE, and brought the Raspberry as close as possible (15 meters clear), but nothing works. Other ZigBee devices are installed on GLADYS.
I admit I don’t understand why I’m having these difficulties.
If you can help me with your advice, it would be useful, as I’ve been trying in vain for 2 days and I’m starting to lose patience!
Thank you for your help,
Bernard
Hello and welcome to the forum :tada:
1. Is the ZLinky properly powered by the Linky?
The ZLinky has no battery or power supply of its own: it draws its current from the TIC output of the meter (I1/I2 terminals). Check that its LED lights up or flashes once connected. If it remains off, the problem lies with the connection or the TIC, not with Zigbee.
2. Put Gladys in pairing mode just before connecting the ZLinky
In Gladys, go to Integrations > Zigbee2mqtt, open the discovery tab, and enable pairing. This authorization is time-limited. Once active, unplug and then replug the ZLinky on the Linky (or reset it as indicated in the Lixee manual) so that it searches for a network to join.
3. Beware of the intermediate router (your bulb)
This is probably the most important point. Some Zigbee routers, particularly many connected bulbs, handle the ZLinky poorly. It may then try to go through the bulb and never complete its pairing. Lixee actually recommends pairing directly with the coordinator. I advise you to temporarily unplug the bulb during pairing. You can plug it back in later if the signal turns out to be too weak.
If nothing works, the logs of the Zigbee2mqtt container will tell us if the ZLinky at least tries to join the network. Run docker logs gladys-z2m-zigbee2mqtt during the pairing attempt, then copy and paste here what appears (for example, an interview failed).
Welcome @Rousber!
I’m not a zlinky specialist, I have one in USB and not in Zigbee, but some tests would be needed.
If you have a Zigbee temperature sensor (for example), do you pick up its signal if you place it near your Linky meter?
A slightly crazy idea comes to mind for pairing: a 15m extension cord with at the end (near the Linky), a Zigbee device (a plug) that will act as a router. There you can start pairing hoping it works.
:face_with_peeking_eye: And after my crazy ideas, I reread and reread your request and I realize that you have already tested the proximity to have a gateway …
Last idea to the c.., you put your RPI at the end of the 15m extension cord and you do the pairing … well you need an Ethernet cable of 15m in the other direction or a good Wi-Fi key.
EDIT: argh @cicoub13 faster than me :sweat_smile:
Good evening, and thank you for your reply. I will try the solutions tomorrow morning. Thank you and have a good evening,
Bernard
Good evening, I’m new to GALDYS. How do you view or create a container log? Good evening, Bernard
You go to Gladys settings by clicking on your name:
Then System:
And finally Download the logs:
In this file, remove personal information (IP address, token, login, password..) if you post it on the forum.
In a private message, it’s a bit less serious (though..).
Hello, mutmut. I looked in the file, but I didn’t find much of anything concrete, and besides, it’s huge.
Well, here are the day’s news. I managed to pair the Linky, with great difficulty. However, there is confusion about the displayed values, it’s a bit of a mess, and I’m missing things, such as the day/night switch. I can’t find the consumption of the 3 phases (I am on three-phase). I also can’t change the refresh rate (I would like either 10 seconds or 30). Does the dashboard display update automatically? Same for the temperatures. Even though I’m not that young anymore (72 years old), with a bit of experience, I admit to being a bit flabbergasted by all these problems.
Thanks to all for your help.
Bernard
Can you take a screenshot of the Zlinky device in the Zigbee2mqtt Devices tab?
It’s to see the features (power, energy, subscription, etc.) available on your Zlinky.
After that, you might need to go into Zigbee2mqtt to see what’s happening as well.
But we’ll take it step by step.
Here’s an example:
answer: yes
Can you take a screenshot of this mess?
Here is a screenshot of ALL THE FIELDS retrieved… The energy consumed is identical and corresponds to the meter index, not per phase. Then the power consumed is at Zero, while there is consumption on all 3 phases!!! Values are also missing, as well as whether I am in day/night mode. Some time ago, I installed a small Arduino, equipped with a card, which allowed me to analyze the phases in order to balance the consumption on my panel, and I had no problems. I am going to install it again. I think I am going to give up all this, return the Lixee, and go back to the TUYA application, or try another home automation program HA in this case. Moreover, currently, I no longer have any feedback from the Linky.
Thank you and have a nice day, Bernard
I just re-paired the Linky to get feedback, which now works, but still incorrect values.
I was talking about my Arduino system, the downside is that the values are written to an SD card, and that I have to go out to retrieve it (meter outside the house). This will allow me to check if the TIC is working properly, before possibly sending the dongle back.
Bernard
It now configures the sensor.
Open the Zigbee2mqtt interface from the integration page in Gladys, then the ZLinky, Settings (specific) tab. Set:
  • linky_mode: historic, standard, or auto;
  • energy_phase: single-phase or three-phase;
  • production: only if you have solar panels.
Then, click on « Reconfigure »
I will add screenshots during the day
Hello, and thank you. I just looked in the tab in question, but I don’t have any settings of this kind. I have:
Time start, with checkboxes « 1970 » « 2000 » « off »
Energy calibration, nothing displayed
Energy precision, with the value « 3 »
Power calibration, with the value « 0 »
Power precision, with the value « 3 »
AC frequency calibration, empty
AC frequency precision, with the value « 3 »
and that’s all, yet I think I’m in the right menu, having looked for others, but nothing found that matches.
Thank you very much, Bernard
Have you been here before?
Gladys > Integrations > Zigbee2Mqtt
Find Lixee and click here (this button only appears if you connect to Gladys locally, not from the Gladys Plus address):
Go to Specific Settings and adjust according to your case:
Well, I don’t know what the spell checker did to me with that superbement :frowning:
Thanks for the screenshot Bernard, but unfortunately it’s not the dashboard I wanted to see (your TEST dashboard) but what’s in the zigbee2mqtt integration as I showed in my screenshot:
And if you can click on the Open in Zigbee2mqtt link and also give us screenshots of the Expositions tab like this example:
And you can also put a screenshot of the Specific Settings as @cicoub13 suggested for the configuration.
I admit that I’m more of a visual person than someone who likes to read long texts because, as I don’t have this module, the text and the names don’t mean anything to me :frowning:
With your Zlinky module, in Exposures you should have plenty of things like this:
Indeed, there are more parameters than at my place, but I think it’s because you are in « standard » mode. I haven’t requested it from EDF, because my little Arduino module can only work in historical mode (the simplest, by default), and if I can’t use the Lixee, I’ll go back to using the Arduino.
Bernard
Here are the requested screenshots.
Thanks to everyone
