Hi everyone! ![]()
Gladys Assistant 5.3.6 is out! ![]()
Last week, 5.3.4 brought a new Zigbee2MQTT setup. This release continues that work: you can now watch your Zigbee devices pair, live, add devices that Zigbee2MQTT doesnât fully support, and the Zigbee2MQTT interface is now password-protected. On the phone side, you can now change a dashboardâs content without opening the editor.
Zigbee2MQTT: follow pairing live
Until now, pairing a device meant allowing new devices to join, then going to the Discover tab and waiting without knowing what was happening. Now, a pairing window shows each device as it joins:
- A countdown (âJoining permitted 3:52â) with Extend and Stop buttons. Joining stops on its own after about 4 minutes, so thereâs no more reminder to turn it off.
- One row per device, with its progress: Joined â Interview â Ready.
- When a device is ready, you see a photo of the model, a suggested name (âLight IKEAâ) and a room, then you click Add to Gladys.
- A device that is already in Gladys shows a link to its page. If the interview fails, you get advice: bring the device closer and pair it again.
- The window is available in step ⣠of the setup wizard, from Pair a device on the Zigbee2MQTT dashboard, and from the Discover tab.
On a phone, the window takes the whole screen:
Zigbee2MQTT: devices that arenât supported yet
Until now, Gladys didnât show devices that Zigbee2MQTT doesnât support, so you couldnât tell what had happened to them. They now appear in a new âNot supported by Zigbee2MQTTâ section at the bottom of the Discover tab:
- If Zigbee2MQTT can guess some features from the deviceâs standard clusters (on/off, brightness, temperatureâŠ), you can add it with these generic features, after a confirmation, because some features may be missing or not work. If a later version of Zigbee2MQTT supports the model, the Discover tab offers Update.
- To ask for a model to be supported, thereâs a link to Zigbee2MQTTâs âSupport new devicesâ page and a Copy the information button (model, manufacturer, clusters) that copies everything they need.
- Suggest this device now opens a pre-filled topic here on the forum, instead of a GitHub issue. You no longer need a GitHub account.
Zigbee2MQTT: a password for its interface
Since 5.3.4, anyone on your local network could open the Zigbee2MQTT web interface, and from there allow new devices to join, remove devices or change settings. It now asks for a password, but you donât have to type it:
- Gladys generates the password and adds it to the links it shows you (dashboard tile, advanced settings, device pages).
- Existing installations get a password the next time Gladys starts (Zigbee2MQTT restarts once).
- If you already set a password yourself in the Zigbee2MQTT configuration, Gladys keeps it.
- You can see and copy the password in Advanced settings.
The first time you open the interface in a browser, Zigbee2MQTT may still show its login screen. Reload the page and it opens without asking.
Home Assistant Connect ZBT-2
With a ZBT-2 dongle, Zigbee2MQTT didnât start (Failed to start EZSP layer with status=HOST_FATAL_ERROR), and the settings you added by hand were erased each time Zigbee2MQTT restarted. Gladys now writes the right settings itself (baudrate: 460800 and rtscts: true).
Forum topic: [Zigbee2MQTT] Home Assistant Connect ZBT-2 : Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR
Dashboard: edit a dashboardâs content without the editor on a phone
Adding a sensor to a widget used to take 9 taps and several screens of scrolling. Now you can do it from the dashboard itself, and every change is saved right away, with an Undo button:
- Long-press a widget to open its menu: add devices, rename or reorder them, move or remove the widgetâŠ
- The â+â button at the bottom of the screen adds a device or a widget directly.
- From a deviceâs page, a new Add to a dashboard button (also on a computer).
- A light now takes one row in the device list, instead of three checkboxes with technical names.
- New devices are named like the ones already in the widget.
Long press on a widget â suggested devices â added, with Undo â or pick where to add it from the â+â:
The editor stays for changing the layout, and itâs lighter on a phone: tap a widget to select it, tap again to open its settings.
And also
- AI chat and cameras: when you ask for a photo (âshow me the living roomâ), Gladys now asks each camera in the room for a new picture, instead of only using one taken in the last hour. This also works with cameras that have no saved image, such as a Karotz. When no picture is available, the AI now says so instead of claiming it took one.
Discussion : prendre des photos Ă la demande - Mode selectors on Android (pilot wire, fan, robot vacuumâŠ): the list kept closing and reopening in a loop, so you couldnât choose a mode. Fixed.
Clignotement sélection mode chauffage sur Android
How to update
If you use Watchtower, Gladys updates on its own within 24 hours. Otherwise, update in one click from Settings > System.
Thanks
Thanks to @cicoub13 for the Zigbee2MQTT work, to @mutmut for the AI chat camera fix, to @gorungeat for testing the ZBT-2 settings by hand, to @gaetanb76 for the video of the Android problem, and to everyone who reports problems on the forum!
If you pair a Zigbee device with the new window, or edit your dashboard from your phone, tell us how it goes below ![]()
