Gladys by the end of 2026: big news and an ambitious plan 🚀
Great! If we can sync the virtual thermostat and the physical one, it will be really convenient
Concretely, I would like:
  • The setpoint change in Gladys to be sent to the heat pump.
  • The change made directly on the physical thermostat of the heat pump to be reflected in Gladys.
 thanks and good luck with the rest of the development.
News on the plan!
:white_check_mark: Custom widgets in external integrations
:white_check_mark: Actions and scene triggers declared by an external integration
:white_check_mark: External integration Energy Contract
:white_check_mark: External integration Calendar
:white_check_mark: Thermostat
:construction: External integration AI
:construction: External integration TTS/STT
If time allows:
:alarm_clock: Custom screens for external integrations → to see if still needed?
:alarm_clock: Complete media player
Can you tell me exactly what this refers to?
This request: [Intégrations externes] Ecrans personnalisés
I admit I haven’t studied the subject at all, I understand that you might want to create more « custom Â» screens on the integration side, a bit like we do with custom widgets.
For a custom energy widget, I created this request: Suivi Ă©nergĂ©tique - avoir un graphique pour le flux d’énergie
Not sure I understand:
VS
I think he shouldn’t have put custom on the first line.
It’s just the arrival of widgets in external integrations.
News about the plan!
:white_check_mark: Energy Contract external integration
:white_check_mark: Calendar external integration
:white_check_mark: AI external integration
:white_check_mark: TTS external integration
:white_check_mark: Complete media player
Thermostat: the last update generated a lot of feedback. I am currently reviewing @Will_71’s work, with the goal of merging it quickly so that these fixes can be published before I leave.
Stability: this is now my priority. With the very rapid growth in the number of external integrations, some things had started to break. I want to make sure that the integration store and Gladys as a whole can continue to grow smoothly during my absence.
Starter Kit: I shipped the last kit yesterday and closed the store, so I can properly support users who just received it.
Apart from a few small UX improvements, I am nearing the end of my new features cycle. The next step is to go on paternity leave with peace of mind :smile: :baby:
:clap::clap::clap: The work accomplished is monstrous. Now we just need to do new integrations to increase the possibilities in Gladys.
You can leave with peace of mind, we are all well equipped to ensure support and maintenance for a few months.
It’s true that the work is impressive.
About two years ago, I was using an eedomus box that worked perfectly, but I was limited in terms of integration.
So I looked for a replacement and naturally turned to Home Assistant because it seemed to support all the connected devices I have. I had also seen Gladys Assistant, which I liked for its philosophy and ease of implementation, but too few of my devices were supported. However, I continued to follow Gladys and then installed it, on a rasp, alongside HA.
And then, in a few months, Gladys was completely transformed. The multitude of external integrations meant that Gladys became the equal of HA (there’s even an integration that I managed to get working under Gladys but not under HA). I’m amazed at what Gladys has become in such a short time.
Now, to be completely won over, all that’s missing is the ability to generate custom widgets (without having to code because I’m totally incompetent in that area), preferably in the form of popups, and Gladys will be, for me, better than HA (and, I think, better mastered and better organized).
In any case, well done because what you’ve done in such a short time is simply impressive.
@pierre-gilles You might even get more than 1000 integrations before you leave.
+825 in 30 days and 856 updates in 1 week. These numbers are crazy!
Is it normal that the numbers are no longer the same and revised downwards 5 hours later?
That’s for sure at this rate!
When you refresh the page, the page first displays the static data at the time of the last site build, then refreshes live with the updated data. It’s possible that in your case, you only see the static data because the refresh failed or was blocked by your browser.
Personally I see this
10 hours later
That’s normal, because there are ongoing developments every day!
I would like to succeed in hitting the 1000 for fun
But I missed
It’s done!
Congratulations to all the developers (and to Claude)!
