I know it’s not in Pierre-Gilles’ P1 order, but I’m taking ORES and SIBELGA to start the new batch of integrations
For information, the new list is integrated
I took seafile and hydroquebec-peak ![]()
Next on the list of 1000, still without material or account, recap here at the exit:
- OpenAI-compatible voice (
tts): any text-to-speech server with an OpenAI API, locally with Kokoro (Kokoro-FastAPI, LocalAI…) or with OpenAI using your key (lines 44 and 169) - Shared custody and shift work (
calendar): a calendar that automatically generates custody weeks (1/1, 2/2/3, 2/2/5/5…) or shift work cycles (2x8, 3x8, on-call duties), for scenes like “children present” or an adapted wake-up (lines 177 and 178) - Maintenance reminders (
calendar): recurring deadlines for the house (boiler, filters, chimney sweep, technical inspection…), with reminders, widget, and a “done” button that resets the counter - Medication reminders: daily doses, a “taken” action from a scene or the widget, and an alert to loved ones in case of forgetfulness
- Recommended shutter position: based on the sun’s position and the orientation of each façade, the recommended closing of each shutter to keep the house cool
If someone was already on it, let me know ![]()
The five reserved wave items mentioned earlier have been released in v1.0.0, all 100% local (except OpenAI if you choose it):
- OpenAI-compatible voice (Gladys 5.3): Gladys speaks with Kokoro locally, LocalAI, Speaches, or OpenAI, one voice per language, with a trigger if the voice server fails. Tested against a real Kokoro in Docker; on a simple processor, Kokoro is slow, so keep announcements short. Not tested against OpenAI (no key). GitHub - guim31/gladys-openai-tts: Gladys speaks with any OpenAI-compatible speech server: Kokoro locally, or OpenAI with your key. · GitHub
- Shared custody and shift work: self-generated calendars, shared custody (1/1, 2-2-3, 2-2-5-5, 3-4-4-3, weekends, custom) or shift work (2x8, 3x8, 5x8, 12 h, on-call, custom), with triggers at the arrival and departure of children or at the start and end of shifts, and a widget. School holiday sharing by half is not managed. GitHub - guim31/gladys-cycles: Alternating custody weeks and shift work cycles as a Gladys calendar, for scenes. · GitHub
- Maintenance reminders: boiler, VMC, chimney sweep, technical inspection… (13 proposed tasks, or yours). One device per task (days remaining, soon due, overdue), a widget with a “Done” button that resets the counter. GitHub - guim31/gladys-entretien: Recurring home maintenance reminders (boiler, filters, chimney, car inspection) in Gladys. · GitHub
- Medication reminders: treatments with their intake times, a “Today’s intakes” widget to check off, and scenes “It’s time”, “Missed dose” (to notify a relative) and “Low stock”. This is not a medical device, just a reminder, and nothing leaves the house. GitHub - guim31/gladys-medicaments: Medication reminders in Gladys: today's doses, mark as taken, alert relatives when missed. · GitHub
- Shutters and sun: one device per facade with the recommended closing of the shutters according to the position of the sun, calculated locally, a trigger when the sun hits the facade and a summer/winter mode. Clouds are not taken into account. GitHub - guim31/gladys-volets-soleil: Advised shutter closing per facade from the sun position, to keep the house cool. · GitHub
Tested in Docker against the fake Gladys of the SDK, not yet on a real installation: your feedback is welcome ![]()
For info, I’ve launched Claude on an Aterno integration
Next in the list of 1000, still without hardware or account, recap here when it’s out:
- AI-on-the-edge: the index of water, gas or electricity meters read by an ESP32-CAM, in MQTT or HTTP, with a trigger in case of probable leak (line N113)
- ChirpStack: the LoRaWAN sensors of a local ChirpStack server, discovered on their own with their decoded measurements (N116)
- OpenMQTTGateway / Theengs: the Bluetooth and 433 MHz sensors decoded by an OMG or Theengs Gateway gateway, read in MQTT (826)
- Meshtastic: the nodes of a LoRa Meshtastic network (battery, position, telemetry), and the messages received or sent from a scene (483)
- Seasonal rental: the arrivals and departures of Airbnb, Booking.com, Abritel… travelers read in their iCal calendars, to preheat or plan cleaning (N46)
Third and final wave of batch 20 (reserved for #454): network, lighting, sensors, and water heaters. The five integrations will arrive at the store on the next indexer pass, and “Install from GitHub” already works with the link of each repository. I don’t have this hardware: everything was tested on simulated devices based on the manufacturer’s documentation and the reference library. Your feedback is precious if you have any.
Common rules: turning off and stopping are never retained and are returned until the device confirms them; a rejected password is never returned alone; nothing secret in the logs, status, or /data.
QNAP QSW v0.1.1: GitHub - LM1LC3N7/gladys-qnap-qsw · GitHub
QNAP QSW manageable switches (QSW-M, M408, M2116…) via the API of their local web interface, in HTTPS with the retained certificate: connected ports, temperature, fans, throughput, uptime, firmware, and per port the link, speed, and throughput. A “Restart the switch” button, disabled by default. PoE is not read. This is not the integration of QNAP NAS.
AiDot v0.1.1: GitHub - LM1LC3N7/gladys-aidot · GitHub
AiDot Wi-Fi lights (Linkind, OREiN, and other brands of the AiDot app): on/off, brightness, color, and white temperature, with changes reported immediately. The AiDot cloud is only used to read the list and keys of the lights, with the application identifier of python-aidot, the official library of the manufacturer; the lights are then controlled locally. Known limit: after a reboot, nothing is sent (even a retained “turn off”) until the cloud has responded.
Wiffi v0.1.1: GitHub - LM1LC3N7/gladys-wiffi · GitHub
Wiffi sensors from stall.biz (weatherman, rainyman, airsniffer, wiffi-wz…): temperature, humidity, pressure, brightness, wind, rain, CO2, and VOCs, locally and read-only. Each Wiffi sends its measurements to a small dedicated container that listens on a TCP port; a Wiffi that is silent for too long is displayed as unreachable. Measurement names vary depending on the model and firmware: let me know if a measurement from your Wiffi does not appear.
Switcher v0.1.1: GitHub - LM1LC3N7/gladys-switcher · GitHub
Switcher water heaters (V2, V4, Mini, Touch), the Power Plug, Runner and Runner Mini shutters, and Breeze air conditioners, via their local protocol, without cloud. Turning on and moving are disabled by default, and each activation of a water heater is sent with a timer from the device. Models that require a Switcher account token are not supported in this version.
MySensors v0.1.1: GitHub - LM1LC3N7/gladys-mysensors · GitHub
DIY MySensors sensor networks, via an Ethernet gateway (TCP 5003) or MQTT: temperature, humidity, pressure, doors, motion, smoke, leaks, light, power, battery… Relays and dimmers only become switches and lights if you declare them safe; turning off does not require any option or declaration. No serial gateway (USB).
Batch 20 is complete with this wave. Your feedback is welcome in the GitHub issues.
I’m taking fifteen new integrations for batch 21, chosen from @pierre-gilles’s list of 1000, by rank. I checked today in @Will_71’s tracker, in this thread (up to #474), in the list topic, in the store, in Gladys’s heart, and on GitHub: none are announced or reserved by anyone else. If I’m wrong, let me know and I’ll remove it.
Voice and Services
- Google Assistant SDK: broadcast a message on Google speakers (line N10).
- YunoHost: updates, services, diagnostics, and server backups (N59).
- TeslaMate: Tesla by self-hosted TeslaMate, in local MQTT and read-only (N61).
- Deutsche Bahn: departures and delays via the official API (500).
- National Rail: departures and delays of British trains via the official Darwin service (N65).
Energy Contracts
- Nettleie og strømstøtte: Norwegian network tariffs and state aid (N20, N35).
- Octopus Energy Deutschland: dynamic tariffs, Intelligent Go, and consumption (N31).
- Netzentgelte §14a Modul 3: German HT, ST, and NT network tariffs by manager (N32).
- ElCom: the electricity tariff of each Swiss municipality (N33).
- OpenEI URDB: the tariffs of American electricity providers (N36).
Home and Meters
- OpenThread Border Router: the status of the Thread network (N5).
- EDF Zen Flex: sobriety days and bonuses in contract calendar (N23).
- MyElectricalData: the Linky meter and the real off-peak hours of the PDL (N26, N47).
- EMS-ESP: Bosch, Buderus, and Junkers boilers locally, hot water capped at 65°C (N51).
- BTicino MyHOME: lights, shutters, and thermostats via the OpenWebNet gateway (689).
I don’t have this equipment or these accounts: the integrations will be tested on simulated servers, except those that read open data. Feedback from those who have them will be precious. They use the latest SDK and are in French and English. I publish them in groups of five, with a summary here each time.
First wave of batch 21 (reserved for #475): voice and services. The five integrations will arrive at the store at the next indexer pass, and “Install from GitHub” already works with the link of each repository. I don’t have these accounts or this hardware: everything was tested on simulated servers based on the official documentation. Your feedback is precious if you have any.
Common rules: no keys, no tokens, and no passwords in the logs, status, or /data; a rejected key is never returned alone; service quotas are respected, with a pause that lengthens in case of refusal.
Google Assistant SDK v0.1.1: GitHub - LM1LC3N7/gladys-google-assistant-sdk · GitHub
A scene action “Broadcast a message” on Google speakers, with an optional room. You connect your own Google Cloud project (the documentation explains how and why to publish the consent screen). Known limitation: Google acknowledged a bug this year for broadcasting on speakers switched to Gemini; I couldn’t verify that they play the message correctly.
YunoHost v0.1.1: GitHub - LM1LC3N7/gladys-yunohost · GitHub
The status of your YunoHost server: version, system and application updates, stopped services, diagnostics, age of the last backup. Four buttons (update the system, applications, launch a backup, restart a chosen service), all deactivated by default. A Let’s Encrypt certificate is accepted normally; a self-signed certificate is retained on the first connection, and a change blocks everything until your approval.
TeslaMate v0.1.1: GitHub - LM1LC3N7/gladys-teslamate · GitHub
Your Teslas via your self-hosted TeslaMate, in local MQTT and read-only: battery, range, charging, doors, trunks, windows, locking, Sentinel, temperatures, tires, odometer. The zone (home, work…) is activated by default; the position is deactivated by default and rounded. The car’s serial number is never read.
Deutsche Bahn v0.1.1: GitHub - LM1LC3N7/gladys-deutsche-bahn · GitHub
Departures and delays from up to 3 stations, via the official Timetables API with your free key from the DB API Marketplace: next departure, minutes before departure, delay, disruptions, filters by line and direction, “departure board” widget. Data under CC BY 4.0 license from Deutsche Bahn.
National Rail v0.1.1: GitHub - LM1LC3N7/gladys-national-rail · GitHub
Departures and delays of British trains, up to 6 boards (one station, and one destination if you want), with disruption messages and scene triggers on a delayed or canceled train. The old OpenLDBWS service no longer accepts registrations: the module goes through its official replacement, the Rail Data Marketplace, with your free key. Powered by National Rail Enquiries.
By the way, without a new version: the tests of nine published integrations (Teltonika, QNAP QSW, airOS, ESXi, ELK-M1, RainMachine, Lennox S30, SPAN, SMA EV Charger) failed about once in a hundred due to a test certificate, and six (RainMachine, SPAN, WARP Charger, OmniLogic, IntelliFire, Guardian) had a frozen version test. This is fixed; nothing changes for you.
Second wave of batch 21 (reserved for #475): energy contracts outside France. The five integrations will arrive in the store at the next indexer pass, and “Install from GitHub” already works with the link of each repository. They add an energy contract model in Gladys: you choose your provider, your municipality or your rate, and the integration calculates the price of each half-hour. The open data has been read for real; none of it has run with a real meter or a real contract. Your feedback is precious.
Common rules: an unknown price is never guessed nor counted as 0 (the half-hour remains without cost, Gladys recalculates it later); the price never depends on the network at the time of calculation; what the Gladys contracts engine cannot express is stated in the documentation and the status.
Nettleie v0.1.1: GitHub - LM1LC3N7/gladys-nettleie · GitHub
Norway: network rate of your provider (77, fri-nettleie data under CC BY 4.0), hour by hour with holidays, consumption tax, Enova and VAT of your zone. Optionally, the spot price with the strømstøtte or the fixed price Norgespris. Strømpriser levert av Hva koster strømmen.no. Limit: the engine cannot bill power tiers (kapasitetsledd); a device displays the month’s peak and the tier reached, and a fixed entry allows it to be counted.
Octopus Energy Deutschland v0.1.1: GitHub - LM1LC3N7/gladys-octopus-germany · GitHub
Germany, read-only: the price of your own Octopus contract (including dynamic tariffs and Intelligent Octopus Go off-peak hours), the consumption of the smart meter, and a “scheduled charging” sensor for the car. The API key is the recommended connection: Octopus announces the end of email and password connection.
Netzentgelte §14a Modul 3 v0.1.1: GitHub - LM1LC3N7/gladys-netzentgelte-14a · GitHub
Germany: variable HT, ST and NT network rates of your provider (about 650, data from Par14a-Database under CC BY 4.0), every quarter-hour. Most of the 2027 grids are still provisional: the status states this and dates the data. Limit: the Modul 1 discount cannot be deducted from the fixed amount, Gladys refuses a negative amount.
ElCom v0.1.1: GitHub - LM1LC3N7/gladys-elcom · GitHub
Switzerland: the rate of your municipality according to your consumption profile, including VAT for the year (Source: ElCom). ElCom only publishes an average annual price, without peak or off-peak hours: each kWh of the year is counted at this price. Corrections published by ElCom are taken into account.
OpenEI URDB v0.1.1: GitHub - LM1LC3N7/gladys-openei-urdb · GitHub
United States: the rate of your provider chosen from the public URDB database (free NREL key), with peak and off-peak hours, seasons, weekends and consumption tiers. Limit: the engine cannot bill the power drawn ($/kW), the minimum bill or the taxes; the subscription is entered manually.
Third and final wave of batch 21 (reserved for #475): house and meters. The five integrations will arrive in the store at the next indexer pass, and “Install from GitHub” already works with the link of each repository. I don’t have this hardware or these accounts: everything was tested on simulated devices and servers based on the official documentation (a real OpenThread Border Router with simulated radio for OTBR). Your feedback is precious if you have any.
Common rules: turning off, stopping a shutter or the heating is never blocked and is returned until the device confirms it; heating writes and sensitive actions are disabled by default, never a switch; no secrets in the logs, status or /data.
OpenThread Border Router v0.1.1: GitHub - LM1LC3N7/gladys-otbr · GitHub
The state of your Thread network via the local API of your OTBR: state, role, number of routers, name, channel and PAN ID. The network key is never read. Disabling and re-enabling Thread are two configuration buttons, disabled by default, to be confirmed in two clicks. Terminal devices are not counted (you would need to wake up battery-powered devices).
EDF Zen Flex v0.1.1: GitHub - LM1LC3N7/gladys-edf-zen-flex · GitHub
EDF Zen Flex Eco, Sobriety and Bonus days in a calendar, a contract model at EDF’s official prices (grid of 15/09/2026) and a scene trigger the day before the announcement. Reading without an account on the EDF website, with the module’s identity. Limits: the module only reads the same day and the next day, a missed day is not caught up (counted as Eco, the status indicates it); a Bonus day is counted as Eco, without the EDF discount.
MyElectricalData v0.1.1: GitHub - LM1LC3N7/gladys-myelectricaldata · GitHub
Your Linky via the MyElectricalData gateway: energy from the previous day, maximum power, production, and optionally the load curve every half hour. A calendar publishes the real off-peak hours of your PDL, with an HP/HC contract model. The cost is only calculated with the load curve enabled. One reading per day, within the gateway’s quotas; the token and PDL are never displayed in plain text.
EMS-ESP v0.1.1: GitHub - LM1LC3N7/gladys-ems-esp · GitHub
Bosch, Buderus, Junkers and Nefit boilers and heat pumps via the EMS-ESP gateway, locally: temperatures, status, modes, setpoints, hot water (up to 65 °C). Writes are disabled by default, except for stopping. With an RC310/RC300 thermostat, stopping is done by “Boiler heating off, all circuits”: it cuts all circuits and can prevent the thermostat from freezing, the documentation details it.
BTicino MyHOME v0.1.1: GitHub - LM1LC3N7/gladys-bticino-myhome · GitHub
BTicino / Legrand MyHOME lights, dimmers, shutters and thermostats via the OpenWebNet gateway, locally, with wall buttons reported immediately. Setpoints and automatic mode are disabled by default. A stop (light, shutter, heating) is kept and returned until the gateway shows it applied, even after a corrected password.
Batch 21 is complete with this wave. Your feedback is welcome in the GitHub issues.
I’m taking fifteen new integrations for batch 22, chosen from @pierre-gilles’ list of 1000, by rank. I checked today in @Will_71’s tracker (up to #478), in the list topic, in the store, in Gladys’ core, and on GitHub: none are announced or reserved by anyone else. If I’m wrong, let me know and I’ll remove it.
Local Home
- IOmeter: the meter reader, index, injection, and power (464).
- TellStick / Telldus: outlets, 433 MHz lights, and sensors, via Telldus Live or locally (1010).
- MiLight / LimitlessLED: the bulbs via the Wi-Fi gateway (615).
- OpenRGB: the PC’s RGB lighting (647).
- Nobø Ecohub: radiators, zones, and modes (954).
Services and Alerts
- Forest Weather: the forest fire danger from Météo-France by department (N67).
- Tessie: the Tesla via Tessie, read-only, including locking (N78).
- Ukraine Alarm: air alerts by region (434).
- Apple WeatherKit: Apple’s weather (711).
- Amazon Polly: Amazon’s voices for spoken messages (N102).
Energy Contracts
- Ostrom: dynamic pricing and consumption (N131).
- Corrently: GrünstromIndex and tariff by postal code (N132).
- Groupe E Vario: the Swiss dynamic tariff per quarter-hour (N135).
- Octopus Energy España: contract and consumption (N138).
- Energi Data Service: Danish network rates, taxes, and spot prices (N145).
I don’t have this equipment or these accounts: the integrations will be tested on simulated servers, except those that read open data. Feedback from those who have them will be invaluable. They use the latest SDK and are in French and English. I publish them in groups of five, with a summary here each time.
