Oh, I didn’t know.
Yes, I imagine you won’t make a fortune with it.
Do you have a link to all the products you have in this store (I don’t know what it’s called)?
How is the security situation with Airtable? What if someone decides to empty the table?
Actually, the affiliation applies to all Amazon FR. Any link you put on the forum, or on the integration page that is on amazon.fr will have an attribute ?tag=gladproj-21 added to the end of the link.
When someone clicks on this link, if the click results in a sale for Amazon, I get a percentage of the sale (Between 0 and 12%, according to a scale described on their website).
There are 2 weeks of history
And anyway, the site is not live with respect to AirTable. It’s only when I rebuild the site locally that it adds the files to the JSON, so everything is versioned in Git. AirTable is just an « open » portal to add devices, but no one can destroy the site.
I just finished adding the photos and links for the Sonoff devices.
If you need to add more, you can go to the official Sonoff website.
Couldn’t we add an info or product doc button?
With a link to the manufacturer’s official website.
The problem is that we need to maintain it, we are not safe from the manufacturer only listing what they produce at the moment. The legacy will not necessarily be preserved.
I’m not necessarily a fan of having a thousand buttons on this view, but in the long term, what I would find great would be to have a page per device on the site with potentially a comment bar, a more complete description of the device, and more links as you say. But well, that requires much more work for the community than simply filling out a spreadsheet with 4 columns…
Hello everyone (it’s been a while)
I just did a fresh install of v4 and I took the opportunity to test the bluetooth.
I have some Xiaomi equipment that partially appears but not completely (only the battery for the moment but it should appear when the equipment refreshes its data I think), it’s this: https://fr.aliexpress.com/item/4000373039226.html
I don’t know at all how to help you: bluetooth tracking, compatible equipment tracking, bug (impossible to assign a room to this detected equipment)?
Do I create a dev topic? Do I report a bug on Github?
Hello everyone!
Thanks to the help of @cicoub13, the integration page of the site now loads both French and English devices.
I need your help with:
- Translating the device descriptions in the « EN » tab of the AirTable
- Changing the French links (amazon.fr) to English links (en amazon.com)
This will allow us to have more devices on the English site.
Quick reminder of the AirTable spreadsheet: Sign up - Airtable
Hello, can you give me write permissions?
In principle, if you log in, you should be able to modify the file, right?
Yeah that’s it, just need to connect
No, I can’t edit
I just checked and indeed there are different rights
read-only, editor, etc.
I am an editor, but I cannot modify the rights.
We will have to wait for @pierre-gilles.
If you click on the link I gave earlier, it will give you the rights! Be careful, this is not the same link as on the Gladys website, that one down there is read-only!
OK, I had to remove myself from the spreadsheet to come back with this link. Thanks
I have translated the titles and descriptions and changed the links to Amazon.com
It’s a bit of a mess in the Philips section:
- titles and descriptions are not uniform
- old models
- English and French standards are not the same (E27, E19, …)
Top @cicoub13 I’ll re-import that ![]()
The old models also need to be listed, because this list allows everyone to know that these models are managed, it’s not just a shopping list.
At the limit, we could manage a special case in the list to say that the model is « old » and is there only to indicate that it is managed but that it should not be purchased
It seems that the page Intégrations | Gladys Assistant is no longer available from the documentation; I searched all over the site and couldn’t find a link.
Indeed, I removed that page from the site in December 2024 ![]()
My assessment is simple: despite an idea that seemed promising, that page never really caught on with the community. The goal was to create a collaborative list of devices compatible with Gladys, but it wasn’t sufficiently populated. Maybe the tool used wasn’t ideal (requiring an Airtable account?), maybe there wasn’t an easy way to report updates… In any case, the current format didn’t work.
The problem is that this page was one of the most visited on the site. But because it was incomplete, it gave a misleading impression of the number of devices compatible with Gladys, which could discourage potential new users.
Yet, if you look at the site’s « Integrations » page:
You can clearly see that Gladys has plenty of integrations!
Maybe one day I’ll try the experiment again with a different format that’s more engaging and easier to maintain. In the meantime, the important thing is that information about available integrations is clear and accessible to everyone ![]()
OK I wanted to make sure this wasn’t an oversight.
It’s true that the procedure for rating products wasn’t the simplest;
We almost all come to the forum, maybe create a dedicated page and when it starts to be well populated you can add a link to it from the documentation.
A bit like this
