Loss of access to Gladys after every update
Hello everyone :waving_hand:
First of all, I wanted to congratulate everyone on the creation of this Gladys Assistant project :clap:
Wanting to discover the world of home automation, I started testing the different solutions and the simplicity and design of Gladys Assistant seduced me.
I installed Gladys Assistant on a VM running on a Freebox Delta. I started with Gladys Version 5.
I encounter a problem with each update. After each update, I end up on the account creation page and I can’t log in with my credentials.
I had installed Watchtower for updates anyway.
I’m turning to you to try to understand where the problem comes from :thinking:
I was planning to test Gladys more, but now I have no access :sleepy_face:
Thanks in advance for your feedback.
Best regards and have a good Sunday.
You didn’t mount your db as a volume
Check this out
Install Gladys Assistant on a Freebox Delta | Gladys Assistant Installer Gladys Assistant sur une Freebox Delta | Gladys Assistant
Hi :waving_hand:
Thanks for your reply, upgrade to DB :thinking:?
Gladys was working but every update makes me start from scratch
I’ve never installed Gladys on a freebox, you must have used a command like this:
docker run -d \
--log-driver json-file \
--log-opt max-size=10m \
--cgroupns=host \
--restart=always \
--privileged \
--network=host \
--name gladys \
-e NODE_ENV=production \
-e SERVER_PORT=80 \
-e TZ=Europe/Paris \
-v /dev:/dev \
-v /run/udev:/run/udev:ro \
gladysassistant/gladys:v5
You should check that you didn’t miss a line in there…
But I have to admit I won’t be able to help you further on this topic, sorry!
Thanks so much for replying already :wink: Yes, I followed the guide with the command lines. I think I’ll delete my VM and start over. I must have missed something. Thanks again
@pierre-gilles after the 2 manual updates I launched today, I no longer have access to Gladys.
Gladys Assistant is installed on a Freebox DELTA VM.
have any idea why?
