Problem connecting to Enedis
Hello Pierre-Gilles,
At the risk of sounding annoying, I don’t have yesterday’s synchronization. I restarted a synchronization a few minutes ago, but it had no effect. The last synchronization is from June 4.
Daniel
Hi @Janssens :slight_smile:
No no it doesn’t bother me at all, on the contrary you should say when something doesn’t work otherwise I can’t know it’s not working :blush:
I looked at your account, and indeed the fix I made yesterday wasn’t sufficient, because since an API call is failing systematically (normal, the Enedis API is still partially broken), your token was subsequently invalidated by Gladys Plus, thinking that your account was no longer « valid ».
I’ve just published a fix that resolves the issue, it should be fine for the next few days! You should normally have the June 5 data on your account :slight_smile:
Thanks so much, I’m keeping my fingers crossed for tomorrow :joy:
