Shopping lists / Listes à cocher
I just installed Gladys after using Home Assistant (the configuration is actually much simpler, especially for Zigbee2MQTT, thanks!)
I can’t find an equivalent of the add-on « Shopping list » which allowed creating (only one, unfortunately) a checklist
Checked items didn’t disappear but moved to the bottom of the list, which is quite handy when you often buy the same things. You could still delete all checked items with a button
https://www.home-assistant.io/integrations/shopping_list/
Thanks
Hi @gsion1 and welcome to the community :slight_smile:
That would be a good idea, yes! I’ll let people vote.
We prioritize development based on votes; if this request gets enough votes (or if someone wants to propose a PR), it will make its way into Gladys :wink:
There’s already a PR for Todoist that seems to meet the need
Hello, I’m interested. Is it possible to install Todoist?
I think this request should go to external integration (if it hasn’t already…)
