Thermostat: request for improvements
@Will_71 review UX + review code posted on the PR!
I have a small request after a few weeks of daily use…
Could you add a delay (or increase it) before applying the heating on/off decision?
I’ve accidentally changed the setpoint temperature several times (while scrolling on my phone), and by the time I adjusted it, the boiler had already turned on/off!
A delay of about ten seconds before sending the command (or customizable) would be great (for reference, the old physical thermostat waited 20 seconds).
@pierre-gilles, thanks I’ve made the corrections
Noted, I’ll see what I can do for this request. Not sure you’ll have it right away with Pierre-Gilles’ leave.
I’ll keep you informed.
A rather cosmetic improvement, but one that would also bring a bit of user comfort: would it be possible to have 6 predefined schedules by default, each corresponding to one of the 6 modes?
This would avoid having to create and display in the schedule list six rather large schedules. They are certainly useful for operation, but their current display is not really relevant, since they simply serve to manage the different modes.
I’ve had a small issue since switching to thermostats: I regularly find that my slave devices no longer communicate with Gladys, or only very little.
In particular, I have a room that currently doesn’t need to be heated. The heating therefore does not activate and, after a while, I no longer have any communication with the device. Gladys then eventually displays “No data”.
However, if I force the device to turn on from the thermostat, communication resumes without any problems.
I wonder if the fact that the devices are no longer used for a certain period of time could explain this loss of communication.
And if there is a way to mitigate this inconvenience
Thanks
Not sure that’s a solution, personally I’m not going to create a schedule per mode. So these 6 schedules don’t interest me at all.
This isn’t really a connection loss.
I think you could open a dedicated topic to avoid cluttering this one.
Don’t hesitate to provide more details about the type of device you’re using and any other information needed to debug.
System settings tab:
Well, on my side, I don’t use the 6 modes, but rather 4:
  • Frost protection or Eco ++: when I go on vacation.
  • Comfort: to find a heated house when I return.
  • Off: during the summer.
The other modes are therefore of little use to me on a daily basis.
In short, in my scenes, I only use the schedules, because the system is really very well designed and allows you to easily manage the different heating modes.
Okay, I understand, but that’s not at all how I handle scheduling, so if we implement this, it won’t suit everyone.
After, if there’s a lot of demand in that direction, then I’ll look into it.
@Prof_Techno I’m not sure I understand what you’re doing :face_with_raised_eyebrow:
Are you using scenes to change schedules where each schedule is just a single mode?
If that’s the case, why don’t you just change the preset/mode directly in the scenes and leave the schedules aside?
Good evening,
I switch to single-mode schedules only for long periods, such as summer or holidays. The rest of the time, I use classic schedules that run continuously.
My idea was mainly to harmonize all my heating management using only schedules. I prefer to have consistent management rather than having to mix, in my scenes, radiators controlled by a schedule and others that operate without a schedule.
The goal is therefore to centralize the operation of all radiators around the same principle: schedules.
Hi @Will_71, I wanted to know where the different PRs on the Thermostat are at?
Are you waiting for testers, reviews? If you can give me a quick update PR by PR :smiley:
I’ll do that for you tonight
Hi @pierre-gilles,
A quick update on my ongoing thermostat PRs to help you navigate them. All four have a green CI and are awaiting your review:
#3327 – Dial range / bounded manual setpoint (bugfix)
Your feedback from 11/13 is addressed in 385e99c44 (details in my comment from 11/13 on the PR). The form only keeps the device range if it restricts the default one, so Matter’s -100/200 is no longer recorded.
#3295 – Lowering heating when presence sensors detect no one
Your two blocking points from 11/13 are addressed in a92c34c2a: a silent sensor is no longer taken for an empty room, and the widget no longer lowers a setpoint set on the dial. Cursor has approved.
#3294 – Reversible heat pump (heating/cooling switch)
Your review from 11/06 is addressed. Rebased on 11/13 after merging #3320 and #3321, with no behavior change.
#3394 – Pilot wire controlled by two switches (new)
This is @spenceur’s latest request: a two-relay module (FIBARO FGS-224…) wired to the pilot wire via two diodes, seen by Gladys as two switches. Feedback from Cursor and CodeRabbit is addressed, and Cursor has approved. A test image is available for spenceur, who has three radiators equipped.
Merge order: all four PRs are compatible with master, but they all touch the same files (edit form, thermostatConstants, applySchedules, the spec). Each merge will therefore require rebasing the others. I suggest starting with #3327 (the bugfix, and the oldest pending), then #3295, #3294, and #3394. I’ll rebase as I go, let me know if another order works better for you.
There are also a few review threads marked “unresolved” on GitHub that are actually addressed (most are outdated): you can ignore them.
Thanks for the time spent on reviews!
Quick update: if I delete a thermostat and had this thermostat on a dashboard, it doesn’t disappear on its own.
Is there a way for the image to disappear from the dashboard while keeping the widget?
A message like: “Edit this widget to select a thermostat.” would be great.
Thanks
Hi @mutmut,
Good catch, it’s fixed: PR #3399.
When a thermostat from a widget is deleted, the widget remains on the dashboard. Instead of the dial, it now displays:
  • This thermostat no longer exists. Edit this widget to select a thermostat.
You just need to edit the widget and choose another thermostat for the dial to come back.
Before, the widget didn’t see that the thermostat had disappeared. It fell back to default settings and displayed the comfort setting (21 °C), with buttons that no longer controlled anything.
If you want to test, the image is available: willde71/gladys-test:thermostat-widget-deleted-device
Thanks for the feedback!
Hi @mutmut,
Thanks again for all your tests of the reversible heat pump. They have significantly advanced the PR. Since your last feedback (post #107 from 02/11), PR #3294 has moved quite a bit: a review by Pierre-Gilles, a rebase on the latest version of Gladys, and some fixes. However, I have never seen it running on a real heat pump. Could you test it again?
The updated image: willde71/gladys-test:thermostat-reversible-PAC (same name as before, just re-pull it).
What has changed and deserves a test:
  1. Switching between Heating and Air Conditioning while the heat pump is running, from the widget, then from the remote control. From the remote control, the setpoint sent must be kept.
  2. Heat pump turned back on by the remote control while the thermostat is off. It should restart in the mode indicated by the heat pump (hot or cold), including during an “Off” slot of the program.
  3. Several rapid mode changes on the remote control, for example hot → cold → hot. The thermostat should end up on the last one.
  4. Edit form:
    • saving a reversible thermostat is now refused, with a message, if the selected mode does not allow cooling;
    • same for a temperature range in reverse air conditioning (min > max);
    • when checking “reversible”, the air conditioning range starts from the range in effect.
  5. The rest, to verify that nothing has regressed: separate hot and cold presets, “Protection” in air conditioning, scenes and program.
If something is wrong, a screenshot of the widget and the logs of the moment (Thermostat lines) will help a lot.
Thanks in advance! :folded_hands:
Thanks @Will_71 for the recap, I’ll check it out as soon as I can this week and get back to you.
