I have this camera model:
https://www.action.com/fr-fr/p/3215672/camera-ip-d-interieur-connectee-lsc-smart-connect/
I understood that this firmware is compatible, but once flashed, can I still access the camera via Tuya or does it switch to RTSP only?
Is it also possible that I lose some features of my camera, such as night vision or two-way audio?
Thanks in advance.
Both work in parallel, no problem.
All features of the original app still work. Only the RTSP stream is enabled.
Great, thanks — I managed to retrieve it via the RTSP stream, but I don’t have anything on Tuya anymore.
but is there a
it’s not working for me, here when I look on GitHub it says that the file anyka_ipc_rtsp must be on the SD card at first boot with the SD card and here nothing gets added
thanks in advance
Petch
Can someone confirm that this motor.cgi file is correct?
When I download it, its size is only 1 KB, which doesn’t make sense.
With this file, the PTZ does not work.
Hello, did you manage to enable RTSP for this camera, please?
hello.
I just bought a camera at Action
Dual-band
But the
Hi!
I’m sorry but after a brief look through the original repo, it seems that the latest firmware you have is currently completely locked…
Oh darn
Isn’t it possible to downgrade it?
Thanks! I just tried it and it works! However, the blue LED stays on all the time. But I was able to cut the camera’s internet connection and keep it running locally! Great! It’s an LSC Smart dual‑band camera, version V3.2863.105, in case that helps. A small detail: I first tried with a 128GB SD card and it didn’t work. Then I did the same thing with an 8GB card (following ChatGPT’s advice
) and it worked! For your information, I had this text translated, so sorry if there are any mistakes ![]()
Have you found a solution for your camera because I have the same issue
