hello
I no longer have access to Gladys, installed on a laptop whose charger broke and since then I no longer have access
On Ubuntu it asks for login and password
I don’t remember them anymore
Is there a solution?
Thank you in advance
hello
Hello @tonio,
The login and password requested at startup are those of Ubuntu, not those of Gladys. There are two options.
1. Check if Gladys is already running
Gladys runs in Docker and usually restarts automatically with the PC, even if no one logs into Ubuntu. From another device on the same network (phone, another PC), open http://PC-IP in a browser. You will find the IP address on your internet box page. If Gladys appears, the Ubuntu password is not even necessary.
2. Reset the Ubuntu password
mount -o remount,rw /
ls /home
passwd your_username
reboot
The command ls /home displays your username. Replace your_username in the passwd command with it, then enter the new password twice.
You will then be able to log in normally. Keep us posted!
Hello @cicoub13
Thank you, for Ubuntu I managed to reconnect, but on Gladys it’s impossible
It asks for email address and password and it doesn’t work
I click on forgot password but I don’t receive the email
What should I do?
Recover your password
Success! I have sent you a password reset link via Telegram or Nextcloud Talk, or a one-time code instead of the link if this address has never been used to log in to your Gladys instance. If you have not configured these services, it will be in the Gladys logs. If you received a code, enter it below to choose a new password.
To access the Gladys logs, go to the command line and type `docker logs gladys --tail=1000` to display the last 1000 lines.
One-time codeBack to login
Need help? Join us on Gladys Community.
I didn’t receive the code by email
I don’t understand why
Just run this command in Ubuntu:
You should see your password there.
this is confusing
permission denied while trying to connect to the docker API at unix
i don’t understand, what does this mean?
I can connect on my iPhone, but I can’t connect on my PC.
There is no email sending server configured. If you haven’t set up a communication channel, only the logs allow you to reset your password.
The exact command is
sudo docker logs gladys --tail=1000
It will ask you for your Ubuntu user password and you should see a link to reset your password.
there is nothing at all
Is there no scrolling text (log) or no password appearing?
When you connect via your iPhone, do you go through Gladys+?
As a last resort, if you have access to Gladys via your iPhone, you can create a new user and set them as Administrator and use this account as your main account…
I did it
I don’t know how to change the password on my phone
Thank you so much
