Gladys redémarre au démarrage
maj 4.72 plante mon gladys.
bonjour, depuis l install gladys ne veut plus redemarrer malgre plusieus manip :
docker stop, docker start…. et meme un arret redemarrage du pc.
symptome : gladys boucle sans fin a faire des start et restart d environ 12 s.
donc pas d acces !
log docker gladys sont full rempli du meme message :
2026-04-04T03:03:19+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:03:37+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:03:56+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:04:14+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:04:32+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:04:50+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:05:10+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:05:28+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:05:46+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:06:06+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:06:24+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:06:42+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:07:01+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:07:20+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:07:38+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:07:57+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:08:16+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:08:34+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:08:52+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:09:12+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:09:30+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:09:48+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:10:06+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:10:25+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:10:44+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:11:02+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:11:22+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:11:40+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:11:58+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:12:18+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:12:35+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:12:53+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:13:12+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:13:31+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:13:50+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:14:09+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:14:28+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:14:46+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:15:04+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:15:24+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:15:42+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:16:00+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:16:19+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:16:39+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:16:57+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:17:15+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:17:35+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:17:53+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:18:11+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:18:32+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:18:49+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:19:08+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:19:27+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:19:46+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:20:04+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:20:23+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:20:42+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:21:00+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:21:19+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:21:40+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:21:57+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:22:15+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:22:34+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:22:53+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:23:11+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:23:31+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:23:51+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:24:09+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:24:27+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:24:47+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:25:05+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:25:23+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:25:43+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:26:02+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:26:20+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:26:40+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:27:09+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:27:28+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:27:47+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:28:06+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:28:25+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:28:44+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:29:03+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:29:22+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:29:40+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:30:00+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:30:19+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:30:36+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:30:56+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:31:16+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:31:35+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:31:54+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:32:13+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:32:32+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:32:51+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:33:10+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:33:28+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:33:46+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:34:06+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:34:25+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:34:42+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:35:02+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:35:20+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:35:39+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:35:59+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:36:17+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:36:36+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:36:53+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:37:14+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:37:32+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:37:50+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:38:10+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:38:28+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:38:47+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:39:06+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:39:24+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:39:43+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:40:02+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:40:21+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:40:40+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:40:57+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
2026-04-04T03:41:17+0200 <info> index.js:101 (Object.<anonymous>) DuckDB initialized with memory_limit=927MB (system RAM: 3090MB)
Salut @Einstein8854 :slight_smile:
Gladys est installé sur quel matériel chez toi ?
Tu confirmes que tu as bien 3 Go de RAM sur ton système ?
Est-ce que ton système n’a pas de problème de ressources ? D’autres containers qui prendraient beaucoup de RAM et donc Gladys qui n’arriverait pas à démarrer ?
c est un vieux pc dell qui tourne depuis que j utilise gladys , 3go de ram, 500 go de hd (490 de libre) et ubuntu22.04 et ce pc est dedié a gladys (seul gladys et les applis connexes y sont : docker, nodered, duckdb,…)
400 go hd libre et non 490 , doigt ont fourché
Et niveau ressources utilisées, tout va bien ?
(J’ai déplacé ce sujet dans une discussion séparée)
apparemment aucun pb a ce niveau;
le seul pb que je rencontre sur ce vieux pc c est la perte un peu trop frequente du lien wifi (pb du dongle apparemment)
depui l installe de gladys sur ce pc (et les petit souci initiaux il y a qq tps de parametrage ubuntu) pas de pb sur le poste (si ce n est matter que je ne parvient pas a activé).
les seuls pb sont sur les petits module zigbee (notamment commutateur derriere interupteur qui nuisent au fonctionnement du commutateur natif, pb de cablage ?)
Tu as une capture d’écran d’un htop ?
Dans les logs que tu montres, Gladys redémarre toutes les 20 secondes environ. As-tu essayé de regarder htop pendant au moins 1 minute, juste pour voir si ce n’est pas l’utilisation de la RAM qui augmente progressivement jusqu’au crash, et ainsi de suite ?
Pour vérifier si c’est vraiment un souci avec Gladys 4.72 (ou si ça n’a pas de lien), tu peux tenter de lancer le conteneur de la version précédente :
gladysassistant/gladys:v4.71.0
Je vois que tu as 2 containers Matterbridge, tu avais dû en lancer un avant toi-même, puis en relancer un nouveau avec Gladys.
Sinon, je ne sais pas si tu as vu mon précédent message ?
Le CPU est à 100% je crois. Si tu tries par usage CPU (F6 puis percent cpu), quel est le process qui consomme le plus ?
Pour monitorer le PC Btop est bien meilleur que top ou htop et tu as le GPU de géré aussi.
hello @pierre-gilles et @cicoub13 ,
desolé pour mon retard de reponse. je suis sur plusieurs choses en meme temps : travaux exterieurs tontes (3000m2), volaille, dev et twitch sur delphi/pascal et evidemment depannage gladys.
1/ Pierre gilles, ai fait comme tu a suggerer docker run gladys/4.71 , install faites (wonderful_poincare) cela tourne depuis 15h (docker ps-a) mais pas acces au frontend via le navigateur.
2/ matter bridge, en effet j avais pas vu, c est vrai que j avais fait une install des que tu avais evoqué ce protocole avant que tu l integre dans gladys (donc je suppose que je peux supprimer l instance hors gladys)
3/ cicoub, vient de faire ce que tu suggere mais sous gladys 4.71 , et <80% la cpu, en effet j avais vu qu en 4.72 c etait 100%+, pour la mem tout roule apparemment.
@cicoub13
hello @ArMour85
connait pas btop, vais voir pour l installer
merci!
Tu as deux instances de Gladys qui tournent en même temps, ce qui peut créer des corruptions de données sur la base + tu as sûrement un conflit sur le port 80
@pierre-gilles , non gladys:v4 est arrêté.
Il a simplement arrêté ce container pour lancer gladys en 4.71
