[Scene] Clear block 1 if empty
Following my request to add a Delete button on the If Then Else condition, I just noticed that you can never delete block 1 (even if it is empty):
The Delete button would appear in block 1 if there is a block 2, otherwise no Delete button in block 1.
Note: this request is similar to the second part of @StephaneB’s request here:
Is no one interested in this request?
I’m interested on my end :slight_smile:
However, I’ve reached the voting limit :grin:
I think it would be more relevant to close this thread and concentrate the votes on [Scènes] Pouvoir insérer un bloc de scène (plutôt qu'un ajout en fin) - #3 par StephaneB which deals both with removing the first block and inserting a block between two existing ones.
@mutmut If you remove your vote there and add it to the other, I’ll close this thread…
@StephaneB, I deliberately opened 2 feature requests to properly separate the requests because in yours you combine 2 into 1 and I remember that @pierre-gilles said 1 request=1 post :wink:
Yes, I have that in mind, and it’s almost always relevant. But here, just for a delete button that already exists on the other blocks, I think it’s a minor request and it runs up against the fact that we’re limited in the number of votes. Hence my idea to include it in the other request…
@pierre-gilles Without calling into question the general principle « 1 request = 1 dedicated message », are you ok with this minor request about deleting the first block being handled in the ‹ insertion of a block › request? To prevent it from being drowned out for lack of votes…
No, I prefer 1 request = 1 post, it’s really more convenient :slight_smile:
Don’t worry about the votes, votes aren’t everything. Small UX requests that take 5 minutes like this one I handle in my UX passes regardless of the number of votes (if they make sense, of course)
OK, that works. So I’ll change the title of the other one to dedicate it to block insertion.
